layer hickup?
Another strange problem that I have never come across :glare: . When I enter comand LAYER and it comes up with all the layers in the file, and I press the add new layer it will just blink and the layer wont apear on the list, so I did it couple of times, it blinked 4 times, no new layers apear. I closed that window, pressed that little arrow in toolbar under layers, all 4 new layers are there with the same colour. If i will select that one layer for instance layer3 and write - LAYER comand again, this layer will apear in the list, but as soon as I move across to a nother layer and press the green checkmark to make it current, that layer will just disapear from the list, seriously, what the :twisted: is going on, hope you can help out guys, as this in not cool
Within the layer manager, on the upper left side, are you currently using a layer filter?
If so, try selecting 'All', and see if that does not correct the issue.
Hope this helps!
yeesss,.... the faded gray selection was on "All used layer" rather than on "All" so once selcted all, I was able to see the new layers, add more and delete as well, so yes this was very helpful, thank you RenderMan!:lol:
