designerstuart Posted October 14, 2010 Share Posted October 14, 2010 hi all i have several dwgs with a dimstlye called x-100 but in each drawing that style has different height text etc. i want to make them all the same. tried using design centre but it says 'duplicate definition ignored'.... do i have to do it manually? if so i would select all dims, change to another dimstyle, purge all dwgs, then re-style the dims? surely there is a better way! thanks Quote Link to comment Share on other sites More sharing options...
qball Posted October 14, 2010 Share Posted October 14, 2010 try the dimupdate or update command. Ribbon as shown on acad 2010, or the Dimension Toolbar edit: oops, I just read that it is for multiple drawings. almost certainly a lisp or macro so you could just use a single command or button, but still in each drawing. Quote Link to comment Share on other sites More sharing options...
nukecad Posted October 14, 2010 Share Posted October 14, 2010 You should be able to change the definition of the dimension style using 'dimstyle' command 'modify' button and then update all the dimensions using '-dimstyle' (note the hyphen), 'apply', select the dimensions to update. Or use 'qselect' to select all the dims and then '-dimstyle' 'apply'. Be careful to watch out for any dims that have been given dimension overrides as applying the modified style will loose these overrides and you will have to put them back. Quote Link to comment Share on other sites More sharing options...
qball Posted October 14, 2010 Share Posted October 14, 2010 i don't much care for overrides. Quote Link to comment Share on other sites More sharing options...
nukecad Posted October 14, 2010 Share Posted October 14, 2010 i don't much care for overrides. Here, Here, they just make things awkward if you want to change anything. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted October 14, 2010 Author Share Posted October 14, 2010 thanks but i don't think this is what i'm after...... i understand how to modify dimstyles, this is a drawing management issue i think. as in, the problem is that someone has already modified my standard dimstyle in each drawing, rather than using a new or other one. so what i really want is some way to reset dimstyles to an original set of properties. y'know like when you insert a block it says "would you like to redefine the block"..... is there a way to do this for dimstyles? would have thought design centre would do it. but when you copy paste dims, they just come in as the 'current x100' as opposed to offering to update. if you know what i mean. Quote Link to comment Share on other sites More sharing options...
qball Posted October 14, 2010 Share Posted October 14, 2010 I think creating a new one called "whatever", inserting it in each drawing, qselect and change all the x100 over to the new one, then purging / deleting "x100" and renaming "whatever" to "x100".... that, but with a Lisp routine. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted October 14, 2010 Author Share Posted October 14, 2010 thanks qball - but my lisping is well beneath that i'm afraid! anyone got another suggestion? Quote Link to comment Share on other sites More sharing options...
designerstuart Posted October 21, 2010 Author Share Posted October 21, 2010 so no other suggestions? i'd be happy enough if someone could tell me it's impossible? just don't wanna do it manually then find a clever way to do it! Quote Link to comment Share on other sites More sharing options...
designerstuart Posted November 17, 2010 Author Share Posted November 17, 2010 so just to clear this up - nobody knows a way to change the definition of dimstyles which is quicker than manually modifying each one in turn? Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 17, 2010 Share Posted November 17, 2010 I've never tried it but have you got the express tool "import dimstyle"? It might do what you are after. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted November 17, 2010 Author Share Posted November 17, 2010 thanks dave that doesn't seem to work either, but it has shown me what the real problem is... but for now i'll have to accept there is no easy answer! thanks all Quote Link to comment Share on other sites More sharing options...
