DVB project is loaded incompletely on Bricscad Pro v10
I got a DVB project developed by someone else and need to get it installed on some workstations that run Bricscad Pro v10; it load and works correctly on all except one. In fact on this troublemaker station it is loaded without error but when try to run his macros get the message "Run-time error 424 Object required".
When checked the loaded components I found that no form was in fact loaded (were about 15 forms) and only few modules are available - compared with station were it works. So, seems that something prevent the DVB file to be loaded completely.
Did someone encounter a similar issue?
Is there a way to debug loaded features since no error is issued when DVB file is loaded?
Any help will be appreciated. Thank you.
Regards,
Mircea
