I have come across a strange issue. While trying to help a co-worker with a plotting issue, I went to create a .pdf file of Sheet 2. When I preview the plot everything looks good but when I plot to a .pdf file and view the .pdf, some of the text is missing.
I have attached three drawings. The main (plottable file) is called CROSSING POINT.DWG and it contains two XREF files, M-CROSSING POINT.DWG (model file) and TB-CROSSING POINT.DWG (titleblock file).
I have attached the drawings and if you open up the CROSSING POINT.DWG file, on Sheet 2, I have clouded an area. Now all the design work is on M-CROSSING POINT.DWG file and the leaders and text are all on the same layer, but why would only the leaders appear but not the text?
I suggested that our ICS Department update her AutoCAD Civil 3D (2011) with the latest updates/service packs because I can't think of anything else it would be that would cause this to happen.
Has anybody come across this same situation?! Oh please email me at (removed email address per request) and I will send you the three files, apparently the files are too large to upload here (it is a compressed file that is just under 3mb) and is clean (no viruses, etc.)
Moderator note: You can contact the author via private message
Edited by rkmcswain
Scooby,
Not a good idea to put your e-mail address in open view like that, leaves you wide open to spammers.
You might want to ask one of the mods to remove it.
I have come across a strange issue. While trying to help a co-worker with a plotting issue, I went to create a .pdf file of a drwing. When I preview the plot everything looks good but when I plot to a .pdf file and view the .pdf, some of the text is missing (see attached .pdf file)
The leaders and text are all on the same layer, but why would only the leaders appear but not the text?
CROSSING POINT SHEET 2 (1).pdf
Very possible that it is Mtext, which is considered a block level entity (not treated the same as a Text string). I do engraver files for our company tags (plastic lamacoids) and an Mtext item will not print. Exploding it into Text items usually works in this case.
Mark
What PDF driver are you using?
Is the mtext annotative?
Try this...
Open the dwg to pdf.pc3 'printer' file. Select custom settings and then the button "Custom settings"
Change the font selection to "capture all"
OK out, save pc3 file, OK out
Jamie
I ran into this problem using the -PUBLISH command in AutoCAD 2009. However using the -PLOT command to plot individual sheets worked without a flaw. Of course then you're stuck with individual PDFs for each sheet so I ended up using a free program call PDFTK to merge the sheets together into 1 PDF. You can use the command line version of PDFTK in conjunction with a LISP program to accomplish this or you can just use the GUI version.
Get the command-line version of PDFTK here.
Get the Windows GUI version of PDFTK here.
