cadman6735 Posted October 14, 2010 Posted October 14, 2010 Where in the visual lisp editor under watch window once I create (vl-load-com) (setq acaddoc (vlax-get-acad-object)) and add 'acaddoc' to my watch window then double click on ACADDOC in the watch window and this opens up the vast wealth of vlisp can I find the xref and xref clip boundry? and if not there, where can I access the xref clip boundry information? thanks Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 Are you looking for the XRef Block object? Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 Xrefs are stored in the Document Block Collection, hence here are two ways: (defun GetBlockObject ( name ) (if (tblsearch "BLOCK" name) (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) name ) ) ) (defun GetBlockObject ( name / block ) (if (not (vl-catch-all-error-p (setq block (vl-catch-all-apply 'vla-item (list (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) name ) ) ) ) ) block ) ) Quote
alanjt Posted October 14, 2010 Posted October 14, 2010 (edited) Just or fun... [color=lemonchiffon](defun GetBlockObject (block) (if (setq block (tblobjname "BLOCK" block)) (vlax-ename->vla-object block) ) )[/color] Edited October 14, 2010 by alanjt Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 I don't think that returns quite the same object Alan :wink: Perhaps this: (defun GetBlockObject ( name / block ) (if (setq block (tblobjname "BLOCK" name)) (vlax-ename->vla-object (cdr (assoc 330 (entget block)))) ) ) Or (defun GetBlockObject ( name / block ) (if (setq block (tblobjname "BLOCK" name)) (vla-objectIdtoObject (vla-get-ActiveDocument (vlax-get-acad-object) ) (vla-get-OwnerID (vlax-ename->vla-object block) ) ) ) ) Quote
alanjt Posted October 14, 2010 Posted October 14, 2010 Well I'll be damned, it is different. I've used that method for layer and just assumed it would for other table definitions. Oh well. Quote
BlackBox Posted October 14, 2010 Posted October 14, 2010 (edited) Here's mine... (defun i:blockItem (arg) (vl-load-com) (cond ((= 'ENAME (type arg)) (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (i:dxf 2 (entget arg)))) ((= 'STR (type arg)) (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) arg)))) Edited October 15, 2010 by BlackBox Remove sub-function calls, added (vl-load-com) Quote
cadman6735 Posted October 14, 2010 Author Posted October 14, 2010 (3) options brain overload... The only problem is, I don't know what to do with it:? Not what I was expecting, (but then again, I didn't know what to expect) I like your second code, it has error catching I am very curiouse about catching errors (I get a lot of them) But for now I would just like to understand how to use this code. I am looking for a way to list my xref blocks and pull the information from them, such as clip boundry and file path, attach vs overlay. I guess this is not a simple task, I just found the watch window the other day and was like holly molly, look at what I can access and this opened the door to an idea I have been wanting to work on. I assumed the variable "block" (in your code above) would allow me to list out the xref blocks, but I get nil. What is vla-item all about, I found an old post of yours but couldn't make heads or tails from it, I am unable to find vla-item in the acad help or developer help. http://www.cadtutor.net/forum/showthread.php?36779-Using-VLA-Item Quote
alanjt Posted October 14, 2010 Posted October 14, 2010 Ahh, just noticed the 330 code in the dump. Shows what assumptions do. Revised: (defun GetBlockObject (block) (if (setq block (tblobjname "BLOCK" block)) (vlax-ename->vla-object (cdr (assoc 330 (entget block)))) ) ) EDIT: nevermind, I see you added it to your prior post. Quote
BlackBox Posted October 14, 2010 Posted October 14, 2010 (edited) I am looking for a way to list my xref blocks Here is one way: (defun i:xrefList (/ xrefList) (vl-load-com) (vlax-for x (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (if (= :vlax-true (vla-get-isxref x)) (setq xrefList (cons (vla-get-name x) xrefList)))) (vl-sort xrefList '<)) I am unable to find vla-item in the acad help or developer help. Check out the apropos (Hint: click the "(A)" button within the VLIDE). :wink: Edit: Or you could select vla-item (or any other function), and hit the help "(?)" button. Edited October 15, 2010 by BlackBox Removed sub-function calls, added (vl-load-com) Quote
alanjt Posted October 14, 2010 Posted October 14, 2010 You can also step through vla-get-filedependencies, but I don't recommend it since it will ignore XRefs that were inserted after last save - I'm really only stating this for informational purposes. Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 Hi Cadman, to answer some of your questions.... I like your second code, it has error catching I am very curiouse about catching errors (I get a lot of them) All of my options have the appropriate error catching, (all are catching the same error of the block not existing), the second code uses the VL apply to catch an actual exception, as vla-item will error when the item at the index specified doesn't exist (whereas most Vanilla methods just return nil - hence the other methods). I am looking for a way to list my xref blocks and pull the information from them, such as clip boundry and file path, attach vs overlay. I believe Renderman has already posted a similar code, but just for completeness of this post: (defun GetXRefs ( / l ) (vlax-for block (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (if (eq :vlax-true (vla-get-isXRef block)) (setq l (cons block l)) ) ) (reverse l) ) I assumed the variable "block" (in your code above) would allow me to list out the xref blocks, but I get nil. Bear in mind that all the options posted are subfunctions - and hence are designed to be called from a main function, supplying the subfunction with the block name as an argument. The subfunctions are designed with a 'useful' return. This means they can be used without any modification whatsoever - really you don't even need to know what the code looks like. All you need to know is what to supply the function and what it returns. In this case, you supply a block name (string) and the function either returns a VLA Block Object from the Block Collection or nil if the block with the name supplied doesn't exist. Example: (setq VLABlock (GetBlockObject "myBlock")) What is vla-item all about, I found an old post of yours but couldn't make heads or tails from it, I am unable to find vla-item in the acad help or developer help. http://www.cadtutor.net/forum/showthread.php?36779-Using-VLA-Item Wow - that is from way back... vla-item is useful in that you can retrieve an item from a collection without iterating through the whole collection to find it - the downside of using such a function is that if you don't know for sure that the object is present in the collection, vla-item may return an error, and crash your whole routine. Hence the use of vl-catch-all-apply, as this will catch such an exception. I would suggest that you look into the VLIDE Help Files, specifically at the ActiveX Object Model - this will give a complete overview of the structure of the various collections and objects in AutoCAD. Lee Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 By the way Renderman, I would suggest that you post the subfunctions referenced by your subfunctions, as the omission of these will only confuse a beginner and renders the code as it stands useless. Lee Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 Ahh, just noticed the 330 code in the dump. Shows what assumptions do. Yeah, as you've probably guessed that is the pointer to the owner object Quote
BlackBox Posted October 14, 2010 Posted October 14, 2010 By the way Renderman, I would suggest that you post the subfunctions referenced by your subfunctions, as the omission of these will only confuse a beginner and renders the code as it stands useless. Dually noted, and thanks for the correction... I've only begun to amass a code library worthy of sharing, and sometimes forget the lengths to which one must 'fill in the gaps' so to speak. Edit: Fixing my posts now.... It's no excuse, but it also didn't help that I have been extremely busy with a submittal, and registering for the State's new *DOT 2011 Kit for Civil 3D/MicroStation Training events. I've been tapped to 'train the trainers' for my Transportation group, and get us cross trained on both platforms (C3D/MS). Should be very interesting. Quote
alanjt Posted October 14, 2010 Posted October 14, 2010 Yeah, as you've probably guessed that is the pointer to the owner object Yup. I was going to correct you on your GetXRefs, but I just noticed you made the necessary modification. Quote
Lee Mac Posted October 14, 2010 Posted October 14, 2010 I am looking for a way to list my xref blocks and pull the information from them, such as clip boundry and file path, attach vs overlay By the way, just to note, this could all be done in Vanilla AutoLISP Some example functions: (defun GetAllXRefs ( / def l ) (while (setq def (tblnext "BLOCK" (null def))) (if (= 4 (logand 4 (cdr (assoc 70 def)))) (setq l (cons (cdr (assoc 2 def)) l)) ) ) (reverse l) ) (defun isXRef ( blockname ) (= 4 (boole 1 4 (cond ( (GetBlockFlag blockname) ) ( 0 )))) ) (defun isOverlay ( blockname ) (= 8 (boole 1 8 (cond ( (GetBlockFlag blockname) ) ( 0 )))) ) (defun GetBlockFlag ( blockname ) (if (setq def (tblobjname "BLOCK" blockname)) (cdr (assoc 70 (entget def) ) ) ) ) (defun XrefPath ( blockname ) (cdr (assoc 1 (tblsearch "BLOCK" blockname))) ) Quote
