Lee Mac Posted October 20, 2010 Posted October 20, 2010 Well, hopefully my explanation helps someone Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Lee Thanks for explaining this to me and I would agree that sub-functions should not be too hard of a concept to grasp. I have a general idea of how they work. - I understand that when you gurus supply your code as examples, you have a collection of libraries that are all sub-functions that you call upon and modify as required for your coding. - The only experiance I have so far with arguments are human supplied, where the code asks the user for info and passes it on to the code for processing. Where in your code above does ( name ) get its info from? - I copied and pasted your code above into my Visual lisp editor and loaded it, I typed at the command prompt (GetBlockObject) and recieved this message: Command: (GetBlockObject) ; error: too few arguments Lee, can I ask you to act like you are me and copy-paste the code you provide above into your visual lisp editor load and run it on a drawing file with an xrefs and tell me if you get the same message as me? Because I am defently missing a concept to make this work. (defun GetBlockObject ( name ) (if (tblsearch "BLOCK" name) (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) name ) )) Trust me, I am learning something from all of this, even if I am missing the point of this thread. Thanks Lee Quote
BlackBox Posted October 20, 2010 Posted October 20, 2010 (edited) Cadman, in your previous post you included some code (a sub-function) that requires an argument. Please open a drawing with a block, and determine the name of any one block... for this example, lets say the block's name is "Block1". Once you load the code you posted above, enter this into the command line: ** Don't forget about (vl-load-com) ** (setq [color=seagreen]blk[/color][color=seagreen]O[/color][color=seagreen]bj[/color] ([color=red]GetBlockObject[/color] "[color=blue]Block1[/color]")) You should get something like this as a result: Command: (setq blkObj (getblockobject "Block1")) [color=seagreen]#<VLA-OBJECT IAcadBlock2 0cd825b4>[/color] What the GetBlockObject function does, provide that you've supplied the block's "name" as the argument, is to return the Vla-Object... for you to manipulate further. Where: "Block1" is the argument GetBlockObject is the sub-function and blkObj is the variable storing the 'Block's vla-object' ... Make sense? Edited October 20, 2010 by BlackBox Clarity Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Renderman, I was just figuring this out from Lee's post and was about to ask if I need to supply a block name such as "MyBlockName" (GetBlockObject "MyBlockName") If this is the case, no wonder I could not figure it out, this example of code was not what I was expecting nor was it what I think I was asking for. I think something got lost in communication... Typing thoughts is so hard. All I am looking for is where can I find a list of xrefs and the properties that go with them in the visual lisp watch window. So I can get a list of xrefs, their file location, clip boundry information and if it is overlay or attached informaiton. Which now I understand there are more functions involved, such as, :isxref and I found the DXF code information in the help menu last night, thanks to Lee vanilla lisp. So I am on the right track. But all this coding got me confussed. If I have to supply an argument for the block I am looking for, what is the point of having the code pull the block for me? This was my mind set and I can see I was thinking about this the wrong way. I am sure I did not explain my issue well enough but learned so much in this process Sorry for my confusion. What seems easy and logical to you gurus is a bit mind bending to us beginners. Thanks all Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Lee, I hope I did not frustrate you too much. Quote
BlackBox Posted October 20, 2010 Posted October 20, 2010 Slight revision... All I am looking for is where can I find ... the [methods and] properties that go with ... [a] visual lisp [object]. Okay, keeping things simple... Use this to list the properties and methods available to a vla-object: (defun c:DUMP (/ eName) (vl-load-com) (if (setq eName (car (entsel "\n >> Select Object to Dump Contents: "))) (progn (textpage) (vlax-dump-object (vlax-ename->vla-object eName) T) (terpri)) (prompt "\n <!> Nothing Selected <!> ")) (princ)) When prompted, manually select an xref, to get the specific properties and methods for an xref. Good luck! Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Stupid Jargon... :wink: Jargon is important... Thanks Renderman Edit... I am waisting you guys time now... I will keep on studying... Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Nice code Renderman very close to what I was looking for... But exactly what I asked for. Thanks Quote
BlackBox Posted October 20, 2010 Posted October 20, 2010 Nice code Renderman very close to what I was looking for... But exactly what I asked for. Thanks You're welcome. I use something similar as a tool when developing. Sometimes I know the property I want, but just want to know a value, etc. Good luck! Quote
Lee Mac Posted October 20, 2010 Posted October 20, 2010 - The only experiance I have so far with arguments are human supplied, where the code asks the user for info and passes it on to the code for processing. If you have written any sort of code, you have experience with argument passing, as you are passing arguments to most LISP functions. Where in your code above does ( name ) get its info from? - I copied and pasted your code above into my Visual lisp editor and loaded it, I typed at the command prompt (GetBlockObject) and recieved this message: Command: (GetBlockObject) ; error: too few arguments This is all answered in my previous post - I also provided an example of how to call the routine. There were many questions in this thread, first, I believe you wanted to query the xref VLA-Object, hence I provided a code to return such an object to you for the specified xref. Later, we provided codes to return a list of xrefs. Quote
Lee Mac Posted October 20, 2010 Posted October 20, 2010 Just to finish off, here are a few functions to get all the information you could want Properties & Methods of XRef Object in Drawing: (defun c:GetSelectedXrefInfo ( / entity ) (vl-load-com) (if (and (setq entity (car (entsel "\nSelect XRef: "))) (eq "INSERT" (cdr (assoc 0 (entget entity)))) (= 4 (logand 4 (cdr (assoc 70 (tblsearch "BLOCK" (cdr (assoc 2 (entget entity)))))))) ) (progn (vlax-dump-object (vlax-ename->vla-object entity) t) (textpage) ) ) (princ) ) Get Propeties & Methods for All XRef Definitions in Drawing (defun c:GetXRefsItemInfo nil (vl-load-com) (vlax-for block (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (if (eq :vlax-true (vla-get-isXRef block)) (progn (terpri) (vlax-dump-object block t) ) ) ) (princ) ) Get Properties & Methods for Single XRef Definition (supply with XRef name). (defun GetXrefItemInfo ( xref ) (vl-load-com) (if (tblsearch "BLOCK" xref) (vlax-dump-object (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object) ) ) xref ) t ) ) (princ) ) Quote
BlackBox Posted October 20, 2010 Posted October 20, 2010 just to finish off... Finish him! I just couldn't help myself. Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Thanks Lee Funny stuff Renderman... This site and you gurus remind me of when I fist started MA... I would watch the black belts and wish to be as half as good as they where. Once I learned the basics got some experiance the rest just fell into place. The only thing that disappointed me was there was no magic involved, just hard work. Lee Alan Renderman I hope to be half as good as you guys someday. Thanks for sharing your knowledge Quote
Lee Mac Posted October 20, 2010 Posted October 20, 2010 I would watch the black belts and wish to be as half as good as they where. Once I learned the basics got some experiance the rest just fell into place. The only thing that disappointed me was there was no magic involved, just hard work. Lee Alan Renderman I hope to be half as good as you guys someday. Thanks for sharing your knowledge I'm sure there are many others much more knowledgeable to add to that list, but you're very welcome CADMan, I appreciate it. Quote
BlackBox Posted October 20, 2010 Posted October 20, 2010 To be included among those I look up to, is quite a compliment, Cadman. ... Maybe there is something wrong with you!? lmao (Just kidding!) Quote
alanjt Posted October 20, 2010 Posted October 20, 2010 Thanks for sharing your knowledge Just giving back a little piece, for the homies. Quote
cadman6735 Posted October 20, 2010 Author Posted October 20, 2010 Renderman Even the orange, green, blue and brown belts are impressive to a white belt... There is something wrong with all of us and I can except that!!! Quote
alanjt Posted October 20, 2010 Posted October 20, 2010 There is something wrong with all of us and I can except that!!! If there's something wrong with all of us, then that's the norm and thus, we're all normal. Quote
BlackBox Posted October 21, 2010 Posted October 21, 2010 Renderman Even the orange, green, blue and brown belts are impressive to a white belt... There is something wrong with all of us and I can except that!!! If there's something wrong with all of us, then that's the norm and thus, we're all normal. ~ Touché, my friends. Quote
