dotted lines appear solid when imported as XREF
I'm working with a floor plan that's got a grid. The grid is imported as an XREF. The strange thing is that in the XREF file, the grid is made up of dotted lines whereas in the importing file, the lines are solid.
Why is this and how can I make the grid lines appear dotted in both files?
Check your ltscale, and set it accordingly.
You may, or may not, need to turn off psltscale.
Edited by BlackBox
Typo
Ah-ha! That was it! Thanks RenderMan
You're welcome. :)
