Can anyone tell me if there is a special way to save rendered 3d drawings ??
every time i try to save it or print it or jpgout, it just looks normal ??
Andy
What do you mean "it just looks normal"? Do you mean to say it is not rendered?
If I understand your question right, you just need to click the File/Save option in the Render window. If all you're doing is saving your drawing file after you do a rendering then you're not saving the image you rendered. You're just saving your autocad drawing file again.
ok i have au unrendered drawing, i select render region, make a window around the unrendered object, then when i click save it only saves the unrendered image.
Bill im not sure where the file save option is in the rendered window
edwin im not sure where the shade plot option is when i click on the plot icon.
thanks
Andy
i just typed saveimg into the command bar and hey presto, still not sure how to plot it though.
