I'm trying to run some code from AutoCAD 2006 in AutoCAD 2011 but it's failing on the thisdrawing.open
Sub main()
ThisDrawing.Open "C:\CGP1-L-099-PI1-93327-09.DWG"
End Sub
Run-time error '-2145386445 (80200033)':
Filer error
Has anyone ever come across this? I've been putting off rewriting this in .NET....
Thanks
I've never looked at 2011, but for 2010 there was a vba something or other that you had to download to get it to work. Same for 2011 maybe?
I've already downloaded and installed the vba enabler for AutoCAD 2011.
Thanks
Try
Dim dwgName As String
dwgName = "c:\Whatever.dwg"
ThisDrawing.Application.Documents.Open dwgName
Thanks
Figured you probably had, but hey, sometimes the obvious is the first thing overlooked.
