simmons Posted October 19, 2010 Posted October 19, 2010 I am using AutoCAD LT 2008 and i've been sent a topographic survey which is a .dwg. I have also been sent 2 accompanying files; a .lin (AutoCAD LT Linetype definition) and a .shx (AutoCAD LT Compiled Shape). Could someone please advise how to insert/import these 2 accompanying files into the original drawing, which opens fine? Many thanks. Quote
hoss Posted October 19, 2010 Posted October 19, 2010 I believe as long as they are all in a same folder Autocad will automatically detect and load them, there is no need to insert /import Quote
ReMark Posted October 19, 2010 Posted October 19, 2010 (edited) No need to insert or import but you do have to load the linetype to use it. Re: shape file. From your AutoCAD Help file: "You must load a shape (SHP) file the first time you need it; it is loaded automatically thereafter. The shape file must be available each time you edit the drawing." Edited October 19, 2010 by ReMark Quote
