ordengate Posted October 20, 2010 Posted October 20, 2010 I'm trying to set up a routine which will convert a pen table setup my company uses and convert it into the layers themselves so line weights and screening is now handled by layer rather than by color. The only thing I haven't figured out how to do is set the layer transparency. Can anyone help me with this? Example: (VL-LOAD-COM) (SETQ ACTDOC (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT))) (SETQ LAYCOL (VLA-GET-LAYERS ACTDOC)) (VLAX-FOR LAY LAYCOL (SETQ LAYCOLOR (VLA-GET-COLOR LAY)) (COND ((= LAYCOLOR 1) (VLA-PUT-COLOR LAY 19) (VLA-PUT-LINEWEIGHT LAY 0.25) (VLA-PUT-TRANSPARENCY LAY 65)) )) Quote
