Hi,
When I masking a text in drawing and create pdf, it look fine, but
When I try to take print out of drawing PDF it come Black background around the text, and text can't be readable,
Can anyone help me create lisp for text masking with 255 Color default use for raster Image.
Edited by prapti
Hi,
What do you have so far?
I don't use the MText masking much, but perhaps use a wipeout?
PDF hates wipeouts. You end up with a half black square over each piece of text.
Ahh - didn't know that :(
Thanks
When I masking a text in drawing and create pdf...
Just curious :Why is masking text used for before print to pdf?
Edited by mdbdesign
Just curious :What is masking text used for before print to pdf?
It's good for regular printing, PDFs just hate it.
What kind of PDFs? What (PDF) Driver are you using?
I can (I dont, but i can) use wipeouts and bg masks in my PDFs no problem. I use Ghostscript.
I have this, but im not sure when or why I wrote it (I dont remember). Feel free to fix it to your needs.
Beware! Background masks applied this way (and not with the Properties palette for example) will result is goofy results if you are using annotative text styles.
(defun c:tbm (/ ssMtext MtextList doffset ent x)
 (and (setq ssMtext (ssget '((-4 . "<OR") (0 . "MTEXT") (-4 . "OR>"))))
      (setq ssMtext (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssMtext))))
 (foreach x ssMtext
   (setq ent (entget x))
   ;; If no background fill exist
   (if	(< (cdr (assoc 90 ent)) 3)
(or doffset
  (setq	doffset
	 (cond
	   ((getdist "\nSpecify border offset factor [1.5]: "))
	   (1.5)
;; mask not present set it.
(setq ent (append ent (list '(90 . 3) '(63 . 255) (cons 45 doffset) '(441 . 0))))
     ;; mask present, kill
     (setq ent (subst (cons 90 2) (assoc 90 ent) ent))
   (entmod ent)
   ;; write the ent
  (command "draworder" "p" "" "front")
;;   (and ssMtext (command "draworder" ssMtext "" "front"))
;;    (Princ "\nThe Masking is complete.")
I've used Acrobat, CutePDF and the default Autocad to PDF.pc3 and never had it work. I gave up on wipeouts looong ago. I generally only need to wipeout a piece of MText here-and-there and I just use the mask built-in to MText. Very interesting. I'll have to give GhostScript a look.
You can avoid this issue by setting the mask on/off with VL. From there, you can edit the color and width with entmod and all will work fine - I've never found a way to change the color/width with VL.
 (foreach x ssMtext
   (or doffset
     (setq    doffset
        (cond
          (1.5)
   (entmod ent)
   ;; write the ent
Se7en Thanks
This lisp's work on Mtext only, not normal text
But any way my problem is solved
Thanks
