Guest balajibth84 Posted October 22, 2010 Posted October 22, 2010 Hai here Balaji.I have the Short code for Laydel.But i want delete particular Layer means how to delete?Can u edit my Code plz? (defun c:Test() (command "Laydel" "n" "Test")) Here i have "Test" Layer.Single command i want to delete this "Test" means How to do that?here? Quote
Tharwat Posted October 22, 2010 Posted October 22, 2010 If the Layer that you want to delete including objects, so you can't delete it. Besides that, should not be current. (defun c:Test() (command "_.Laydel" "_n" "test" "" "_Y") ) Tharwat Quote
Tiger Posted October 22, 2010 Posted October 22, 2010 If the Layer that you want to delete including objects, so you can't delete it. Besides that, should not be current. Tharwat That is the point of LAYDEL, that you can delete the layer even if it contains objects - which makes the command a little bit scary. Quote
Tharwat Posted October 22, 2010 Posted October 22, 2010 That is the point of LAYDEL, that you can delete the layer even if it contains objects - which makes the command a little bit scary. Thank you Tiger, You're absolutely right. I 've used this command for a long time . Quote
