PeterPan9720
Blocks Replace
PeterPan9720
Hi to everybody,
Is there a way to modify the tools blocks replace available in Autocad Express Tools ?.
I try to explain better :
- The express tools blocks replaces "all" blocks inside the dwg comparing the name.
- I would like to change only selected ones ? Is there a way to have access to express tools blocks replace "macro" and starting from that create another only for replace the selected one ?.
Somebody think that could be easier create complete new tools for my issue ?
Many thanks for all your support
Share this post
Link to post
Lt Dan's legs
Like match properties but matching blocks?
Share this post
Link to post
PeterPan9720
I did not understood well your answer, but the original function matches the old blocks attributes with the new also.
My mod would be works in the same way.
Thanks
Share this post
Link to post
ReMark
If I understand you correctly you have, for example, 12 instance of block "ABC" in your drawing. Of these 12 you may only want to change 6 of them not all of them. Is that right?
Share this post
Link to post
Lt Dan's legs
(defun c:mb (/ *error* ent ss ssent id)
 (defun *error* (msg)
        (princ (strcat "\n** Error: " msg " **"))
   (setvar 'nomutt 0)
 (while
   (not
     (and
(setq ent (car (entsel "\nSelect source block: ")))
(eq "INSERT" (cdr (assoc 0 (setq ent (entget ent)))))
   (prompt "\nPlease select a block!!")
 (redraw (cdr (car ent)) 3)
 (prompt "\nSelect blocks to replace: ")
 (setvar 'nomutt 1)
 (repeat (setq id (sslength (setq ss (ssget '((0 . "insert"))))))
   (setq ssent (entget (ssname ss (setq id (1- id)))))
   (entmod (subst (assoc 2 ent)(assoc 2 ssent) ssent))
 (setvar 'nomutt 0)
 (redraw (cdr (car ent)) 4)
Share this post
Link to post
PeterPan9720
Yes, correct.
Selecting that on screen, even if are in different layers.
Thanks
Share this post
Link to post
PeterPan9720
Yes, correct.
Thanks
Share this post
Link to post
PeterPan9720
   (setvar 'nomutt 0)
 (while
   (not
     (and
 (setvar 'nomutt 1)
 (setvar 'nomutt 0)
Seems to work fine, I'll try to select more than one
Many thanks
Share this post
Link to post
Sweety
   (entmod (subst (assoc 2 ([b][color="red"]entget[/color][/b] ent))(assoc 2 ssent) ssent))
You have forgotten to add entget function dear dan
Best regards
Share this post
Link to post
PeterPan9720
Seems that with your modification doesn't work !
Share this post
Link to post
CADapult
WooHoo! I had logged in to ask about the very same issue. Lt. Dan's legs, you sir are awesome! With a couple of small tweaks this will do exactly what I need and save me several hours of fumbling around working out the code. Thank you for helping me to end my very bad week on a high note!
Mike
Share this post
Link to post
Lt Dan's legs
Your welcome
Share this post
Link to post
alanjt
Watch out when replacing attributed blocks.
Share this post
Link to post
Lt Dan's legs
this correct Alan?
   (setvar 'nomutt 0)
 (while
   (not
     (and
 (setvar 'nomutt 1)
   [b][color=red](entupd ssent)
[/color][/b]  )
 (setvar 'nomutt 0)
Share this post
Link to post
alanjt
Entupd works on the entity, not it's data. Try entupd (cdr (assoc -1 ssent.
However, I'm talking about what will happen if you replace an attributed block. Try it, you will notice the attributes of the former block are still there. You will have to step through it (using entnext) and entdel each attribute.
I use the following; the replacement will only take on the rotation and size of the selected block and the original is just deleted.
http://www.cadtutor.net/forum/showthread.php?48458-Replace-Selected-Block-Or-Blocks-With-Another-Block&p=359585&viewfull=1#post359585
BTW, nice work. You are really coming along with your coding.
Share this post
Link to post
PeterPan9720
Thank you to everybody for the support,
The last code seems to work fine only if the "destination" object to replace is a single object.
If I select more than one object just the last selected object will be replaced.
Pls Help Me.
Share this post
Link to post
PeterPan9720
Thank you for your support but seems that your code do not transfer the attributes during the replacement, I need also to do this.
The best would be a mix between the two lsp, yours for multiple selection and the last from Lt Dan for the attributes.
Thank you !
Share this post
Link to post
PeterPan9720
this correct Alan?
   (setvar 'nomutt 0)
 (while
   (not
     (and
 (setvar 'nomutt 1)
[/color][/b]  )
 (setvar 'nomutt 0)
Thank you for your support, but seems that the above code substitutes only the block attribute and not the complete block with the source blocks attributes.
Thank You
Share this post
Link to post
