3D device help
I have a device with a plan block and a model block. I've created a device with these blocks. When I bring it into a new file it work fine with the plan view and a 3d view. However when I bring it into a construct with a back ground it will only see the plan view in both top down and SW iso. I've purge mep object to make sure nothing was interferring and same result. What could be the cause of this?
