bigmaz Posted October 26, 2010 Posted October 26, 2010 Hi guys A small query really. Any one know of a shrter way to access the imageframe variable? I am going in and out of drawings having to type this every time. Is there a keyboard command that is shorter? Cheers Martin Quote
lpseifert Posted October 26, 2010 Posted October 26, 2010 Try the Aliasedit command... you can make any shortcut you want (almost). You can also make a shortcut in the CUI > Keyboard Shortcuts Quote
profcad Posted October 27, 2010 Posted October 27, 2010 There is a express tool named TFRAMES that toggles frames on/off. Quote
Kapanther Posted October 27, 2010 Posted October 27, 2010 You could always add the following lisp code to your acad.lsp or a lisp that loads every time you open a drawing (command "imageframe" 0) this way it will turn image frames off straight away. as soon as you open a drawing. Quote
