MikeP Posted October 26, 2010 Posted October 26, 2010 Since you cant explode a circle. I need to be able to convert a circle to a poly line. Quote
ReMark Posted October 26, 2010 Posted October 26, 2010 As previously suggested by profcad: Use the BOUNDARY command and pick a point inside the circle. AutoCAD will create a polyline on top of the circle. This polyline can now be assigned a width. Quote
jcap91163 Posted October 26, 2010 Posted October 26, 2010 Use this application, load it from the appload dialog box and you'll have the option to convert circles to polylines. circle2pl.zip Quote
MikeP Posted October 26, 2010 Author Posted October 26, 2010 thats what i have been doing, but i then have to delete the circle. and honesty im just lazy lol Quote
pBe Posted October 26, 2010 Posted October 26, 2010 As previously suggested by profcad: Use the BOUNDARY command and pick a point inside the circle. AutoCAD will create a polyline on top of the circle. This polyline can now be assigned a width. simple like that ... Quote
Tharwat Posted October 26, 2010 Posted October 26, 2010 Here is mine hope you like it ............ (defun c:C2PL (/ o e) ; Tharwat Tue 26.10.2010 (if (and (setq o (car (entsel "\n Select Circle :"))) (eq (cdr (assoc 0 (setq e (entget o)))) "CIRCLE") ) (progn (vl-cmdf "_.donut" (* (cdr (assoc 40 e)) 2) (* (cdr (assoc 40 e)) 2) (cdr (assoc 10 e)) "") (vl-cmdf "_.erase" o "") ) (princ) ) (princ) ) Tharwat Quote
ReMark Posted October 26, 2010 Posted October 26, 2010 I just need a lisp for the donut's hole. Anybody have one? Quote
David Bethel Posted October 26, 2010 Posted October 26, 2010 Dunkiitthhpp Dounuttthhppp with a liissttthhppp Quote
ReMark Posted October 26, 2010 Posted October 26, 2010 I meant one for the "void". I need to create the "nothing". Quote
MikeP Posted October 26, 2010 Author Posted October 26, 2010 for what im using this for, it kinda sounds stupid but it will actually help me. Quote
MikeP Posted October 26, 2010 Author Posted October 26, 2010 perfect except can i have it be able to select multiple circles rather than one at time? Quote
alanjt Posted October 26, 2010 Posted October 26, 2010 I meant one for the "void". I need to create the "nothing".but The Nothing will kill Fantasia and all that inhabit it. Quote
alanjt Posted October 26, 2010 Posted October 26, 2010 (defun c:C2P (/ ss) ;; Circles to LWPolylines ;; Alan J. Thompson, 10.26.10 (if (setq ss (ssget "_:L" '((0 . "CIRCLE")))) ((lambda (i / e d l) (while (setq e (ssname ss (setq i (1+ i)))) (setq l nil) (foreach x (setq d (entget e)) (and (member (car x) '(6 8 39 48 62)) (setq l (cons x l)))) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 2) (cons 70 1) ) l (list (cons 10 (polar (cdr (assoc 10 d)) 0. (cdr (assoc 40 d)))) '(42 . 1) (cons 10 (polar (cdr (assoc 10 d)) pi (cdr (assoc 40 d)))) '(42 . 1) ) ) ) (entdel e) ) ) -1 ) ) (princ) ) Quote
The Buzzard Posted October 26, 2010 Posted October 26, 2010 Since you cant explode a circle. I need to be able to convert a circle to a poly line. MikeP Try this lisp, It draws the circle as a closed polyline made by two arcs. (defun C:CIR (/ CDIA CPNT PT01 PT02) (or CIR:CDIA (setq CIR:CDIA 1.0)) (initget (+ 2 4)) (setq CIR:CDIA (cond ((getreal (strcat "\nSpecify circle diameter. <"(rtos CIR:CDIA 2 4)">: "))) (T CIR:CDIA))) (setq CDIA CIR:CDIA) (while (if (/= (setq CPNT (getpoint "\nSpecify center point: ")) nil) (progn (setq PT01 (polar CPNT (CIR_DTR 0.0)(/ CDIA 2.0))) (setq PT02 (polar PT01 (CIR_DTR 180.0) CDIA)) (CIR_DLWP (list PT01 PT02 PT01)(list -1.0 -1.0 -1.0) 0)))) (princ)) (defun CIR_DLWP (VRT BF FLG) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length VRT)) (cons 70 FLG)) (apply (function append) (mapcar (function (lambda (PNT BF) (list (cons 10 PNT) (cons 42 BF)))) VRT BF)))) (princ)) (defun CIR_DTR (a)(* pi (/ a 180.0))) Quote
