How can change from INCH to MILLIMETER?
Hi,
If i have something in from Inch units to Millimeter?
Thank you.
1 inch = 25.4mm
I'm asking if I can open for example the Arbor Press in Tutorial files or anything that was made in Inch in Millimeter.
On the Units Tab under document settings, you can change to your desired measurement standard.
Nevermind. I didn't see that you are using Autocad 2009. I don't think my head is on right today.:?
ReMark, JohnK_TEDCF, JD Mather , thank you for your help :)
i didn't find "Tools>Document Settings>Units " in Inventor.
what i want is the Arbor Press which is in Inch in Inventor, i want it in Millimeter. Is there any tools to do that in Inventor?
Yes, Tools>Document Settings>Units.
