Johnathan Chen Posted October 28, 2010 Posted October 28, 2010 Hi there, Just singed into this forum. I would appreciate the help of you guys, when needed. And of course, if I can eventually help, i will. Just as the topic title says, i want to unfold a surface of a frustum cone. I just installed the plug in: unfold surface. But somehow it doesn't do what it says. when i want to use the command i get this error: error: You must select surface entity! what am I doing wrong? Cheers, JC Quote
Cad64 Posted October 28, 2010 Posted October 28, 2010 Are you selecting a Solid? The error is telling you that you need to select a Surface entity, not a Solid entity. Quote
Johnathan Chen Posted October 28, 2010 Author Posted October 28, 2010 I converted the solid to a surface, but still getting the error Sideline information: I am also new to 3D modeling, so maybe i am doing something totally wrong. for years I've been using autocad, but only 2D modeling. Been using sketchup for 3D. Quote
Johnathan Chen Posted October 28, 2010 Author Posted October 28, 2010 Ding Dong..! It worked..! Quote
airsoldier2001 Posted October 28, 2010 Posted October 28, 2010 (edited) HELLO there ! hey, I am going throu the same problem here . I don`t get the same error like U, I have a surface to unfold, I have installed the program (by the way , are you using the software from solid3dtech or U got`it from someone else ?) , I enter the "unfoldsurf" command , select the surface to unfold, press enter , then it prompts me to select curves , points , for unfolding, but as I try to select a line , I get selected all the surface and I don`t manage to unfold the surface ! Could U please tell me what I`m doing wrong and how I should proceed ? Thank U ! Regards ! Edited October 28, 2010 by airsoldier2001 Quote
Johnathan Chen Posted October 28, 2010 Author Posted October 28, 2010 I'm using the software from solid3tech. when you press the command, then select the surface. after that, i ignored the commands and just pressed enter. the 2d surface of your 3d model should be generated automatically. maybe you can't see it at once, because of your view.press the 'top view' and then you'll see your out-folded (2d) surface. Quote
airsoldier2001 Posted October 28, 2010 Posted October 28, 2010 I think it`s something else , I`ve turned the view all up and down, and all around, but I can`t get the unfolded plan of the surface .I can`t believe`it I got stuck so close to the finish Quote
Johnathan Chen Posted October 29, 2010 Author Posted October 29, 2010 That really sucks..! but as i said earlier, i'm not used to 3D modelling in autocad. So this is all i could think of that could've been wrong. Sorry i cant't help out.. Quote
airsoldier2001 Posted October 29, 2010 Posted October 29, 2010 I think my problems come from the software , I can`t even unfold the samples from solid3d examples . Is it possible to send U my project and do the unfolding for me ? There are like 4+1 surfaces to unfold .Thanks ! Quote
Johnathan Chen Posted October 29, 2010 Author Posted October 29, 2010 I can try it out. Sent me a PM.. Quote
scj Posted October 30, 2010 Posted October 30, 2010 There are 4 unfolded surface areas. I suppose the backside is already flat. The unfolding was made in BricsCad, so you will get an information when opening in AutoCad. The unfolded patterns are located in the xy-plane. Regards Jochen forunfolding_5.dwg Quote
airsoldier2001 Posted October 30, 2010 Posted October 30, 2010 Thank U very much for your help !Best Regards ! Quote
