endlasuresh Posted October 28, 2010 Posted October 28, 2010 i am trying to draw a gear but while making teeth i am getting trouble.i followed this tutorial .Please let me know how to do from the steps 6 Quote
shift1313 Posted October 28, 2010 Posted October 28, 2010 You will have to be a little more specific about what you are having trouble with. I just read through it and everything seems fairly straight forward so let us know exactly what part you are stuck on. Step 6 is clicking on the face to start a new sketch. In the screen shot they show you which button they are pressing. You can also press Sketch on the ribbon bar sketch tab and then select the face to start a new sketch. Quote
endlasuresh Posted October 29, 2010 Author Posted October 29, 2010 at the step 9 i had problem for making dimensions in degrees however clicking on both lines i got the measurement and i have done the gear Quote
SolidWorksEngineer Posted November 17, 2010 Posted November 17, 2010 Why you don`t use SolidWorks Toolbox.. There are all Standart gears.... I don`t see the reason, why you have do to double work Best Regard, SolidWorksEngineer.com Quote
