How do I write a lisp program that will set the drawing to a black background?
Often, people are in my drawing, change it to white and save it. I can change it back the conventional way but it is annoying and takes a lot of time. (6 drawings each day)
A lisp program that recalls a profile would be helpfull but is there a way to do it without reseting to a saved profile?
If the background color is set under the options, then preferences, Display then you should not need to change it. AutoCAD should keep your preferences.
I have worked with others who prefer a white background and they have sent me their drawings and when I open them the background is my default / black background.
This makes scense to me and how I though acad would run
However, I sometimes open a drawing that has a white background. Do I have something set wrong?
This may help somewhat: http://www.civil.bcit.ca/faculty/thu...FAQ2_copy.HTMl It details the use of the WMFBKGND variable. This can be....
I didn't understand the above
  • 1 month later...
