naghshe Posted September 18, 2008 Posted September 18, 2008 I have STANDARD as text style when I look in PROJECTS, DRAWING SETUP, TEXT STYLE. Usually when I type text in MULTILINE TEXT it has ARIAL as text fond, for the new project it suddenly changed to TXT. I have to change the font to Arial each time I type. Is there any way to change the font of a project to what you need? Thanks Quote
rkmcswain Posted September 18, 2008 Posted September 18, 2008 Set up your required textstyles in your template drawing(s). Then when you start a new drawing, they will be there. Same for layers, dimstyles, table styles, and everything else saved in the drawing. Quote
naghshe Posted September 18, 2008 Author Posted September 18, 2008 Thanks, I found out that "-style " is the command I need to change the font and i made changes to my template. Quote
