Tyke Posted November 1, 2010 Share Posted November 1, 2010 When working in 3D I can obtain the 3D (slope) distance between any 3D points. The results are the slope distance, delta X, delta Y, delta Z, angle in X-Y plane and angle from X-Y plane. What's missing is the 2D distance between the two points. I vaguely remember someone once telling me there is a way to get that 2D distance, but I can't seem to find a reference anywhere about it. Is it possible to get the 2D distance between two 3D points? There is enough information there to calculate it. Quote Link to comment Share on other sites More sharing options...
eldon Posted November 1, 2010 Share Posted November 1, 2010 i expect there is a clever lisp somewhere, but if you draw a line between the two points and then List it, the length in the current UCS (2D length) is given as well as the 3D Length, amongst other info. Quote Link to comment Share on other sites More sharing options...
Tyke Posted November 1, 2010 Author Share Posted November 1, 2010 Thanks Eldon. I've just got round to working that one out myself, but you were quicker. But drawing a line, listing it and then deleting it is a bit over the top just to get the information displayed which is actually there, somewhere. I have a VBA macro which does the calculation and displays the results in a message box, so I have no problem doing it. We work with a company who just have AutoCAD 2011 without VBA and my contact there has asked for my help with the problem. Quote Link to comment Share on other sites More sharing options...
eldon Posted November 1, 2010 Share Posted November 1, 2010 In fact, by doing a search, I found this thread which seems to be what you want Quote Link to comment Share on other sites More sharing options...
SEANT Posted November 1, 2010 Share Posted November 1, 2010 Or, if AutoCAD LT compatibility is an issue, this thread has a Command Macro that removes the Z displacement from the calculation: http://www.cadtutor.net/forum/showthread.php?22977 Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 1, 2010 Share Posted November 1, 2010 Interesting. When I did a LIST on a line drawn in 3D between two different elevations I got this: LINE Layer: "0" Space: Model space Handle = 3aa from point, X= 20.8057 Y= 17.9927 Z= 1.0000 to point, X= 20.8137 Y= 28.5582 Z= 3.0000 In Current UCS, Length = 10.5654, Angle in XY Plane = 90 3D Length = 10.7531, Angle from XY Plane = 11 Delta X = 0.0080, Delta Y = 10.5654, Delta Z = 2.0000 Quote Link to comment Share on other sites More sharing options...
Tyke Posted November 1, 2010 Author Share Posted November 1, 2010 Okay, we have the solution It's governed by a System Variable "OSNAPZ" osnapz=0 --> 3D-Distances osnapz=1 --> 2D-Distances You can have the 2D distance OR the 3D distance, but not both. I believe the default value is osnapz = 0. But it works a treat and is exactly what was needed here. Thanks guys. Quote Link to comment Share on other sites More sharing options...
rkent Posted November 1, 2010 Share Posted November 1, 2010 You can use .xy filter on the second point. Dist, osnap to endpoint, type .xy, osnap endpoint of other end, finally osnap to the first endpoint to use the same z value. Quote Link to comment Share on other sites More sharing options...
Rebel Posted November 1, 2010 Share Posted November 1, 2010 Isn't that what the very first dimension is from the distance command? eg: Command: di DIST Specify first point: Specify second point or [Multiple points]: Distance = 16'-7 15/32", Angle in XY Plane = 32, Angle from XY Plane = 12 Delta X = 13'-9 9/32", Delta Y = 8'-7 15/16", Delta Z = 3'-4 3/4" Quote Link to comment Share on other sites More sharing options...
rkent Posted November 1, 2010 Share Posted November 1, 2010 Isn't that what the very first dimension is from the distance command? eg: Command: di DIST Specify first point: Specify second point or [Multiple points]: Distance = 16'-7 15/32", Angle in XY Plane = 32, Angle from XY Plane = 12 Delta X = 13'-9 9/32", Delta Y = 8'-7 15/16", Delta Z = 3'-4 3/4" Only if OSNAPZ is set to 1, I keep it set to 0 so I use filters. Quote Link to comment Share on other sites More sharing options...
dumfatnhappy Posted November 1, 2010 Share Posted November 1, 2010 I just pull a tape on the fly (using linear dimension) since it cannot see 3D if the ucs is set to plan/top/world Quote Link to comment Share on other sites More sharing options...
