I just upgraded to AutoCAD 2011 and now I'm having issues extracting block attributes using dataextraction.
Problem:
The values of the attributes are not extracting. The tag is extracted but the value, even though it is filled in, is not extracting. I have comfirmed that it works when using autocad 2010.
Is there a SETVAR that I need to change? I have tried changing BVMODE but it still doesn't work.
Thanks for your help.
Sorry forgot to mention that the attributes that are not extracting are not visible. The visible attributes of the block extract fine. It is only the attributes that have visiblility turned off....thanks,
I just tried it with 2011 and it works fine for me. i made a length attribute invisible and it still comes out good with the data extraction.
