input coordinates from a text file
I need to input coordinates from a text file
I wrote a lisp but I'm sure there is a much easier/cleaner way to do the same
This inserts a block
I type in excel 479.61 on a column and 22 in another
I then glue these two together as
(COMMAND "-insert" "lsection" "479.61,22.00" "" "" "")
(DEFUN C:555 ()
(COMMAND "-insert" "lsection" "596.51,22.00" "" "" "")
(COMMAND "-insert" "lsection" "611.69,22.00" "" "" "")
(COMMAND "-insert" "lsection" "620.42,22.00" "" "" "")
(COMMAND "-insert" "lsection" "638.62,22.00" "" "" "")
Give this a shot:
(setq fp (open "c:\\coords.txt" "r") lst '() i 0)
(while (setq a (read-line fp))
 (setq lst (cons a lst))
(close fp)
(repeat (length lst)
 (command "._insert" "lsection" (nth i lst) "" "" "")
 (setq i (1+ i))
Give this a shot:
(close fp)
 (setq i (1+ i))
Thank you! this saved me a day or two of work
:shock:
How do I change this to look at 2 files?
c:\\xcoords.txt"
c:\\ycoords.txt"
or (probably better. don't know if it is practical/possible)
have my text file look like
x
165.26
164.37
332.58
412.40
y
21.00
21.00
21.00
21.00
instead of
165.26,21.00
164.37,21.00
332.58,21.00
412.40,21.00
You can also leave it as an Excel file and open it throught VBA or Dot Net. If no one posts it first I will post tomorrow.
Try this. It should allow you to pick from a list of existing blocks and select an Excel file to retrieve the points list from.
Sorry about the lack of comments in the coding but I hope it helps.
Points.zip
Thank you very much for your help. I'm always amazed at the help here. It's sometimes better than a paid service.
It also embarrases me a bit. You have gone through all this work and I know nothing about VBA. I have never used it but I'll probably figure it out. However I don't know how to edit it or taylor it to my needs.
