ArcGIS for AutoCAD with BING/Google maps
Hi all
Not sure if this is quiet the correct place for this thread.
Just started using ArcGIS for AutoCAD 2007 [Release Build 200.0.3349.2540].
I have been succesful in importing maps from http://server.arcgisonline.com/v93/
Is it possible to set up ArcGIS to import from either google or bing maps into AutoCAD (Vanilla)?
Thanks
Jammie
  • 10 months later...
Hi
I've done something similar in Autolisp on downloads of Google Earth, Yahoo Maps, Bind, etc.. Also on multiple servers elevation data and other information, via APIs.
I expose all:
http://sofitosoft.blogspot.com/
Greetings
Hi
I expose all:
Greetings
That looks interesting. Will have to read it using Google translate lol.
I've used ArcGIS before although never in collaboration with a CAD program.
Hi
I apologize for not having a bilingual version, but have a little introduction - summary in English. On the page "English version"
I hope your comments.
Regards
  • 4 months later...
@SOFITO_SOFT Thanks for the link & for replying to the post. Sorry for not getting back sooner. For the moment I don't need GIS capabilities with AutoCAD but I will consider your link in the future. Thanks again
I will also try to be "quiet"...
But why are you trying to import information from Google Maps...? That stuff cant' be trusted. You really need a real survey done. Otherwise, you're opening yourself up to a world of hurt, unless all you care about is a "conceptual plan".
I also think that you should completely forget about trying to use Autocad 2007 for Civil work. Go to C3D 2012. It's got a huge learning curve, but it's worth it. And Autocad 2007 is completely inadequate for this type of work. (Although if all you care about is GIS-type fuctionality, you may also be able to get by with Map 2012.)
