Unit Accuracy Question
In VBA i'v been doing myself a little program to help me with my mm to inches and vica versa conversions, however when i do 1 mm to 1 inch when i run the program it's coming out with a large string of numbers, what do i need to do to get it to show accuracy within 2 decimal places?
Here's the code for the button at the moment.
Private Sub Cmd_run_mm_Click()
   Me.Lbl_mm_to_inch_answer.Visible = True                      ' makes the label visible
   Me.Lbl_mm_to_inch_answer.Caption = Me.Value_box.Value / 2.54 ' Divides the value in the text box by 2.54
End Sub
without looking myself have a look at the FORMAT command. You should be able to give it a mask to copy. (I think)
Using the help function to find the format option i've added an extra string to the code, but I'm still getting a P.E.B.K.A.C error!
Lbl_mm_to_inch_answer , MyStr = Format(5459.4, "##,##0.00")
End Sub
[/Code]
try this...
    Me.lbl_mm_to_inch_answer.Caption = Format(Me.Value_box.Value / 2.54, "####0.00") ' Divides the value in the text box by 2.54
