Is it possible to trim a block without exploding it?
Also is it possible to explode a block and have it maintain its properties?
Thanks
Could you expand on that a bit please. Where do I find that one? I am using Autocad 2008.
Just type in CLIP at command line and flollow instructions. You can also look in help if you need furture assistance. Happy clipping.
There is another tool named CLIPIT. It on the Express Menu->Modify->Extended Clip.
Typing CLIPIT in command line asks to select object but will not let me select a block. Keeps saying invalid selection.
The Clip command wasn't introduced until 2010
Under Using shows 2010, but later After I answerd came back and said he/she was using 2008.
Nevermind I will use the superhatch command. I have to add a couple of lines to close boundary but works faster than copying the block over and over.
When using CLIPIT, you have to select the cliping object first, then the block. It works fine on 2005, so it should work in 2008.
Command: CLIPIT
Pick a POLYLINE, CIRCLE, ARC, ELLIPSE, or TEXT object for clipping edge...
Pick an IMAGE, a WIPEOUT, or an XREF/BLOCK to clip..
Edited by profcad
typo
Will this not work with a line? Does it have to be a POLYLINE, CIRCLE, ARC, ELLIPSE, or TEXT object for clipping edge?
It will not work with a line. Draw a closed polyline around the part you want keep. Then run the command.
Thanks. extra work but a lot less than exploding and worrying about it that way.
XCLIP should work, I think CLIP is just an alias for XCLIP added in 2010.
Ok, how do you use XCLIP? I can' t seem to make it work. Basically trying to CLIP insulation inside stud wall.
_______________
|XXXXXXXXXXXX|XX
X = insulation
_ = wall boundary as a line
Crude but should point out what I need to do. CLIP insulation at second | mark.
That way it ends up like this.
_______________
|XXXXXXXXXXXX|
Thanks
Maybe you would be better off with a routine for drawing insulation. Do a search on the web for batt.lsp, or insulation +lisp
dynamic blocks with array and stretch work for Batting as well. For me anyway, some might require more flexibility with scales, etc.
