how many types of drawing
Hi
how many types drawing r their in autocad ?
their alot of drawing r thier like sharp drawing
can pls anybody help me
thx
If you mean file-types, AutoCAD uses a few yes:
DWG is the main drawing format
DWL is a lock-file that is usually automatically deleted when you close the file
DWF/DXF are both compressed files designed for distribution (if I remember correctly)
There are more file-types that AutoCAD uses, but a search on Google or Help can give you more info than I can give you.
Was that what you are asking?
You can draw just about anything using plain AutoCAD but if you work in the architectural field you might want to use AutoCAD Architecture. Likewise, if you work on road design you might choose to use AutoCAD Civil 3D.
What types of drawings do you create?
i am asking about Architecture help me
OK. Help you what?
Are you drawing a floor plan? Maybe some elevations? A foundation plan? A roof plan? A wall section? Details? Are you putting together a door and window schedule?
What do you need help with exactly? Please be detailed in your response. The more you tell us the better we can assist you.
i want to know wht are the types of drawing in Architecture
I mentioned several types of architectural drawings previously. Are you refering to residential versus commercial? I don't know what you mean by "types". Please explain.
i had attended the interview yesterday i had came to know abt new things which i had not know it before
i know only abt how to make a like area elevations and fence
they asked me abt pecil drawing and i said wht is it ? and i dnt know abt tht bcoz iam the beginner so i lift from thier i want to know more abt plaining
If you are working on a commercial project the seven major groups of drawings will be:
Site
Architectural
Structural
Mechanical
Plumbing
Electrical
Fixtures
Most residential plans consist of:
Site plan
Floor plan(s)
Elevations
Foundation
Section(s)
Some house designs may also require roof and floor framing plans, cabinet elevations and layouts (including millwork details), stair layout, fireplace details as well as electrical, plumbing and HVAC plans.
Pencil drawings? The company doesn't use CAD to create their drawings?
Do you have any manual drafting experience at all?
is their any branchs in Architecture
no i dnt have any manual drafting experience at all
Branches in architecture? You mean "specialties"?
Yes. A couple that I know of would be cabinetry and closet layout. There are whole industries built around these two specialty fields.
If the job you are applying for requires manual drafting we're talking about a whole new set of skills you would have to learn.
pls explain me wht is this pencil drawing
Imagine doing all the work you would do in CAD, linework and lettering, but in pencil and on a sheet of vellum.
You would need:
Drafting board or table.
A drafting lamp.
Adjustable drafting chair.
Triangles (30/60 and a 45/90).
Parallel arm or a drafting machine.
Circle template.
Architectural floor plan template.
Bow compass.
Dividers.
Mechanical pencils with different lead thicknesses (0.3mm, 0.5mm, 0.7mm and 0.9mm).
Electric eraser.
Erasing shield.
Drafting tape.
Protractor.
Architectural scale.
Irregular or french curves.
Lettering guide.
Soft gum eraser.
White pencil eraser.
Dusting brush.
