I can't slice or delete faces or do anything on a 3d solid i have done. why is that? Properties say it is a 3d solid but cant do anything
unfortuately it is too big to post.
when you try to slice, what error does your command prompt display?
Command: _slice
Select objects to slice: Specify opposite corner: 1 found
Specify start point of slicing plane or [planar
Object/Surface/Zaxis/View/XY/YZ/ZX/3points] : xy
Specify a point on the XY-plane :
Specify a point on desired side or [keep Both sides] :
SLICE failed for selected solid.
