Copy object multiple times at a curved line
Hey guy's,
Got a question once i saw a teacher copy an object multiple times at a curved line.
Now i've got an curved line and i need to copy multiple lines on the curved line, but the line have te rotate with the curved line...
does any body have a solution ?
thanks
If the object is a block try either the Measure or Divide command. Yeah, I know, it sounds stupid but it does work.
If i type the command measure and i fill down the right number... what i need to do after it ? to get the objects at the cross'
Another possibility is to use the ARRAY command with the polar option. You'll need to give it the angle to fill, but you can get that from the arc's properties.
The "object" must be a block. You would use the Block option of the Measure command.
Are you working with an arc that has a single radius or a complex curve with more than one radius?
it is an single curve with just 1 radius of 350 meters.
Then you have three choices and they were all mentioned above. There is nothing more to add.
