Hi,
I'm looking for an autocad techniques to do the following things in 3d:
1. way(s) to union two non co-planar faces
2. way(s) to offset region
3. way(s) to extrude the unified non-co-planar faces
4. extruding a region with a closed path
Thank you in advance.
Regards,
Nicolas.
  • 2 weeks later...
1. I just union'd 3 surfaces with different z values and different angles, worked fine. It created a kind of block with a grip at the middle of the mass.
2. Appears you can't offset a Region. Just have to copy.
3. Extrudes objects all in the same direction.
4. Not sure what a closed path Region is.
