James1 Posted November 11, 2010 Posted November 11, 2010 I have a drawing that is in a coordinate system and has been drawn in mm however I need to retain its relative coordinates but convert the drawing into m for the sake of a realtime navigator. Can anyone help? Quote
edwinprakoso Posted November 11, 2010 Posted November 11, 2010 create a new drawing with m unit, then insert your drawing there. You can use XREF or insert block. But you need to define the UNITS correctly for each drawing. Quote
eldon Posted November 11, 2010 Posted November 11, 2010 If you scale by 0.001 about the 0,0 point, then all coordinates stay the same, but with the decimal point shifted along Quote
edwinprakoso Posted November 11, 2010 Posted November 11, 2010 True But by inserting, it is very flexible for any kind of units. You can easily convert feet and inch too. Quote
eldon Posted November 11, 2010 Posted November 11, 2010 As I read the thread, the OP was interested in mm and m conversion, and my reply was aimed specifically at that. I sure he will be delighted to know that he can deal with inches as well Quote
