Hello. :)
Hope that someone would tell me how to remove the space from the selected text or mtext .
(setq e (car (entsel "\n Select Text :")))
(setq ent (entget e))
(entmod (subst (cons 1 .......
Not specifically the contents are known .
Thanks GUYS.
  • Replies 62
  • Lee Mac
    15
  • alanjt
    14
  • Michaels
    8
  • Sweety
    8
Posted Images
Remove the space, or replace it with something else?
Edit:
I guess removing is the same as replacing with an empty string "", huh.
No. just remove the space from the selected word from the selected text .
Thanks
(defun c:FOO  (/ ss)
 (vl-load-com)
 (vla-startundomark
   (cond (*activeDoc*)
         ((setq *activeDoc*
                 (vla-get-activedocument (vlax-get-acad-object))))))
 (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
   ((lambda (i / e v s)
      (while (setq e (ssname ss (setq i (1+ i))))
        (setq s (vla-get-textstring (setq v (vlax-ename->vla-object e))))
        (while (vl-string-search " " s)
          (setq s (vl-string-subst "" " " s)))
        (vla-put-textstring v s)))
     -1))
 (vla-endundomark *activeDoc*)
 (princ))
Edited by BlackBox
Code re-posted
(defun noSpaces (str)
 (if (eq (type str) 'STR)
   (vl-list->string (vl-remove 32 (vl-string->list str)))
FYI Mat, if you are going to edit entities as vla-objects, it's faster to use vla-get-activeselectionset than to step through the selectionset and convert to vla-objects.
Dually noted.
Thank a lot gentlemen .
Renderman your routine works great .
Alanjt Please take a look
(setq tt (cdr (assoc 1 ent)))
(noSpaces tt)
in the Visual Visp console I see the changes but that does not affect at the selected text.
What's wrong in the previous codes.
many thanks
You will need to update the entity with the textstring returned by Alan's function.
I wanted to challenge myself to avoid the use of VL:
[ Scroll down after you have got something working on your own   ]
(defun c:nospace ( / nospace ss )
 (defun nospace ( s )
     (lambda ( o )
       (repeat (strlen s)
         (if (/= 32 (ascii s))
           (setq o (strcat o (substr s 1 1)))
         (setq s (substr s 2))
       o
 (if (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
     (lambda ( i / e )
         (entupd
           (cdr
             (assoc -1
               (entmod
                 (subst
                   (cons 1
                     (nospace
                       (cdr
                         (assoc 1 (entget e))
                   (entget e)
     -1
Edited by Lee Mac
If you didn't realize that it would only edit the string and not the object, then you need to learn the basics of editing objects before you go any farther.
Wow Lee Thank you .
I really wanted to see it in Vanilla . your way of looping the codes make me crazy .:)
Although with entupd function it's not replacing the text :o
(noSpaces tt)
(entupd ent)
(defun noSpaces (str / v)
 (if (eq str "")
   (if (eq (setq v (substr str 1 1)) " ")
     (noSpaces (substr str 2))
     (strcat v (noSpaces (substr str 2)))
YES , I am sorry now it works OKI.
(entupd (cdr (assoc -1 (entmod (subst (cons 1 (noSpaces tt))(assoc 1 ent) ent)))))
Many thanks Alanjt
I am sorry again for misunderstanding.
Wow Lee Thank you .
You're welcome, glad you got there in the end :)
Yeah ... I am so embarrassing with my mistake with (entupd and entmod) they shown me as a stupid .
Thanks a lot Lee
Thanks a lot Lee
A person is only as stupid as they allow themselves to be.
Not completely , because the lack of informations is not a kind of allowing others to call me that way .
Maybe in some situations but not all. :)
Well, you were the only one that called yourself stupid.
Also, you just grabbed and used a bit of code provided without studying it first - you would have realized that it only altered the string and did nothing to an object. Any limitations you incurred were of your own accord. I gave you the means to remove the spaces, if you are attempting you edit strings, you should already have a working knowledge of editing objects and not rely on me or anyone else for that.
BTW, I really like the repeat from the string length idea, Lee. However, why'd you worry with converting the string to an ascii character when (eq s " ") would have sufficed?
Are you saying stupid is as stupid does?
