Are you sure the space at the end remains? QUOTE]
Good catch. The space at the right of the text string is removed by your code post. I only need to lose the the space preceeding the text string.
Code:
(defun c:removespcs ( / e str l p) (vl-load-com)
(while (setq e (car (nentsel)))
(if (and (vlax-property-available-p (setq o (vlax-ename->vla-object e)) 'TextString)
        (setq str (vla-get-TextString o)) (vl-string-search "  " str))
 (while (setq p (vl-string-position 32 str nil t))
               (setq l (cons (strcat " " (substr str (+ 2 p))) l)
                              str (substr str 1 p)))
 (setq str (vl-string-left-trim " " (strcat str (apply 'strcat (vl-remove-if '(lambda (j)(eq j " ")) l))))
                     l nil)
               (vla-put-textstring o str)
The addition of this code:
Did not accomplish this either... is that why you said "Hang on"? :facepalm: Thanks.
Ooopsie! I forgot I changed the command name and it was calling the old code up. My bad. It works great! :notworthy:
Edited by ryoerger
  • Replies 62
  • Lee Mac
    15
  • alanjt
    14
  • Michaels
    8
  • Sweety
    8
Posted Images
Works fine here mate.
Give me a real sample.
EDIT: I see you edited your post.
Glad it works for you.
Cheers.
Yes it does. Refer to my previously modified post. Thanks again pBe!:D
