Lisp routine to print layout tabs and exclude model tab
I'm trying to create an ACAD2000 lisp routine that will print only Paperspace tabs. This is what I have so far:
(defun c:Plt (/ )
 (foreach layoutname (layoutlist )
   (command "._layout" "set" layoutname )
   (command "-plot"
"yes"
layoutname
"\\\\sbserver\\Canon ir3235"
"LETTER"
"INCHES"
"PORTRAIT"
"NO" ;PLOT UPSIDE DOWN
"LAYOUT"
"1:1"
"0.00,0.00"
"YES" ;PLOT WITH PLOTSYTLES
"MONOCHROME.CTB"
"NO" ;PLOT WITH LINEWEIGHTS
"NO" ;SCALE LINEWEIGHTS WITH PLOT SCALE
"YES" ;PLOT PAPER SPACE LAST
"NO" ;REMOVE HIDDEN LINES
"NO" ;WRITE THE PLOT TO A FILE
"NO" ;SAVE CHANGES TO LAYOUT
"YES");PROCEED WITH PLOT
It works
BUT
some of my AutoCad files incorporate the Model tab into the layout list and I don't want that. So to rectify the problem, i'd like to place a model tab exclusion string into the lisp code.
I sourced this piece of code from the internet. It compiles an alphabetic layout tab order and removes the Model space tab from its list. How can I incorporate that piece of code into my existing routine?
;create list of layout tabs (in proper order)
(defun layouttablist (/ lst)
 (vlax-map-collection
   (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
   '(lambda (x) (setq lst (cons x lst))))
;;  sort in tab order
 (setq lst (vl-sort lst '(lambda (x y)
                           (< (vla-get-taborder x) (vla-get-taborder y)))))
;;  make list of names into strings  remove Model space
 (setq lst (vl-remove "Model" (mapcar '(lambda (x)(vla-get-name x))lst)))
Thanks
Alternatively, another possibility:
(foreach layoutname
 (mapcar 'cdr
   (vl-sort
       (lambda ( / l n )
         (vlax-for x
           (vla-get-Layouts
             (vla-get-ActiveDocument
           (if (not (eq "MODEL" (strcase (setq n (vla-get-Name x)))))
             (setq l (cons (cons x n) l))
         l
     (function
       (lambda ( a b )
         (< (vla-get-TabOrder (car a)) (vla-get-TabOrder (car b)))
Or, in Vanilla perhaps:
(foreach layoutname
   (lambda ( dict / def l n )
     (while (setq def (dictnext dict (null def)))
       (if (not (eq "MODEL" (strcase (setq n (cdr (assoc 1 (reverse def)))))))
         (setq l (cons n l))
     (reverse l)
   (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT")))
You could just use something like:
(vl-remove "Model" (layoutlist))
(layoutlist) doesn't include Model.
Yeah, I didn't think so either - but the OP states that some of his files do include it.
BUT some of my AutoCad files incorporate the Model tab into the layout list
Wild. Must be an freaky thing with older versions. Might have something to do with files that could have been created with r14 (before layouts existed).
To answer the OP's question:
Replace: (foreach layoutname (layoutlist )
With: (foreach layoutname (layouttablist)
So I tried replacing layoutlist with layouttablist and got the following:
Command: (layouttablist)
; error: no function definition: LAYOUTTABLIST
This is what I get when I simply use layoutlist in the offending drawing:
Command: (layoutlist)
("Layout1" "Model")
Mind you, if I use layoutlist in other drawings, it works fine and i'll get:
("Layout1")
So I suspect something is up inside that specific offending drawing. A setting or switch i'm not aware of.
I incorporated (vl-remove "Model" (layoutlist)) into the code but it didn't eliminate the model tab selection.
(defun c:Plt (/ )
 (vl-remove "Model" (layoutlist)) ;<---------------
   (command "-plot"
"yes"
layoutname
"etc etc...."
Then I copied the following into my routine
(defun c:Plt (/ )
 ;(foreach layoutname (layoutlist )
(foreach layoutname
 (mapcar 'cdr
   (vl-sort
       (lambda ( / l n )
         (vlax-for x
           (vla-get-Layouts
         l
     (function
       (lambda ( a b )
   (command "-plot"
"yes"
layoutname
"etc etc...."
and that does the trick. Hopefully I won't run into any other problems. Thanks for your help!
I can now use this lisp file in conjunction with EZScriptpro and print the approx 400 drawings to complete my project. I didn't like Batch Plot Utility because it would open all the drawings and slow my computer down. With EZScriptpro, it opens a drawing, runs the lisp file, closes the drawing and continues the process. Thanks!
The original isn't working because you didn't add the subroutine you posted to your code. Load it in AutoCAD and try it again.
(defun c:Plt (/ )
   (command "-plot"
"yes"
layoutname
"etc etc...."
This is because you incorporated it incorrectly:
(defun c:Plt ( / )
 (foreach layoutname [color=red][b](vl-remove "Model" (layoutlist))[/b][/color]
   (command "._layout" "set" layoutname)
   (command "-plot"
"yes"
layoutname
"etc etc...."
Works great and thanks for the clarification.
Lastly, now that you've provided two different ways to accomplish the same task, is one routine superior to the other?
edit:
Scratch the question. I see that one of them organizes the tabs.
You're welcome :)
In most (but not all) cases, the more concise solution is usually quicker.
