The way I usually work with AutoCAD2007 is
(to MOVE an object) select object>"Move">Space bar>drag
(to delete an object) select object>"Del"key
and all of a sudden, (or I accidentally hit some keys),
I have to work the other way around,
(to MOVE an object) "Move">Space bar>select object>drag
(to delete an object) "Erase">slect object>space bar
Any idea that how do I get back to the preivous setting?:(
MANY THANKS!
:shock::shock::shock:
PROBLEM SOLVED!!! BIG THANKS!!
