modifying AEC default wall fill colors / hatch
I there any way to change the color of the default hatch/fill in the standard ACA walls?
I recently used the standard 8" concrete wall which ACA fills with a std. concrete hatch, which is fine I guess, but it uses color 30 which I always have had as a thick line. I don't really want to change my pen settings right now - I'm just so used to them that I "see" colors as their thicknesses.
I know I could create my own custom wall, but I don't really want to mess around with that. I would like to still use the correct walls so that I can maybe start trying to take advantage of whatever BIM capabilities ACA has.
Edit the wall style, go to the materials tab, click on the material you wish to change, then in the upper right hand side of the window is the "edit material" button, click on that. Then choose your display representation, and all the stuff you would need is right in there.
