My 1st question is how would I get the 3 Linear Dimensions circled in Red in the attached image below to show in Meters and not MM? The boxes are drawn in MM so maybe that is why? I changed my units to Meters and redrew the boxes buy they came out tiny.
My 2nd question is can I get the Linear Dimension to show like the dimension circled in Blue in the attached image below. I mean somehow suppress the dimension and the extension lines so only the dimension shows?
Any help would be great.
I'm not at my CAD computer at the moment but with regards to question 2, the display of extension lines, etc. can either be done in your dim style or via the Properties dialog box.
Add 1 - change dim scale to 0.001 and add suffix "M"
