Miro Posted November 16, 2010 Posted November 16, 2010 does anybody know how to tell if your graphics card is on its way out? my graphics card is NVIDIA GeForce 9600 GT & i am running AutoCAD 2011 with windows XP Quote
edwinprakoso Posted November 16, 2010 Posted November 16, 2010 Have you tried to check certified hardware list on Autodesk site? http://usa.autodesk.com/adsk/servlet/hc?siteID=123112&id=6711853&linkID=9240618 Quote
ReMark Posted November 16, 2010 Posted November 16, 2010 What kind of problems are you experiencing that makes you think your graphics card is on its way out? Quote
Miro Posted November 16, 2010 Author Posted November 16, 2010 i think my graphics card may be on its way it beacuse occasionally my dialogue boxes in AutoCAD don't fully appear, but is there any real way of telling whether it is about to stop working prior to it happening? Quote
Miro Posted November 16, 2010 Author Posted November 16, 2010 i tried the autodesk site and it seems to be certified, but is there any way of telling if the graphics card is about to stop working prior to it happening? Quote
nestly Posted November 16, 2010 Posted November 16, 2010 i think my graphics card may be on its way it beacuse occasionally my dialogue boxes in AutoCAD don't fully appear... Are you using a Logitech mouse by chance? Their SetPoint software does that to mine. Quote
Miro Posted November 16, 2010 Author Posted November 16, 2010 No, i am using a microsoft wheel mouse optical Quote
ReMark Posted November 16, 2010 Posted November 16, 2010 Have you tried to reseat the graphics card? Quote
ReMark Posted November 16, 2010 Posted November 16, 2010 Shut down the computer. Unplug the power cord. Disconnect the cable to the video card. Open up the case. Touch the metal frame of the case to ground yourself. Remove the video card and then reseat it firmly in the slot. Reverse the steps. Start up your computer. Test it. Another question for you. Do you have the latest drivers installed? Are you experiencing problems with any other Windows based programs? Quote
Miro Posted November 16, 2010 Author Posted November 16, 2010 i'll give that a go later, thankyoui i'm not sure if i have the latest drivers, should i go to the nvidia website and update the drivers also? no i don't have any problems with other windows based programs, just AutoCAD 2011 Quote
ReMark Posted November 16, 2010 Posted November 16, 2010 If you are NOT having problems with any other Windows based programs then STOP. Do NOT bother trying to reseat the graphics card as you are NOT having a graphics card problem. Are you working in 2D or 3D? How much RAM is installed in this computer? Quote
Miro Posted November 17, 2010 Author Posted November 17, 2010 I am working in 2D i have 2.00 GB of RAM, do i need more RAM? Quote
ReMark Posted November 17, 2010 Posted November 17, 2010 Windows XP? I'm guessing you are running the 32-bit version of your OS and AutoCAD too right? How much videoRAM on the graphics card? 2GB of RAM? Yes, I'd say you probably do need more RAM. Quote
Miro Posted November 17, 2010 Author Posted November 17, 2010 Yes windows XP not sure if its 32 bit - how do i find out? how do i find out how much videoRAM is on the graphics card? Quote
ReMark Posted November 17, 2010 Posted November 17, 2010 Right click on My Computer and select Properties. It should tell you if it is 32-bit or 64-bit. Who put this computer together? How is it that you don't know your own system specs? Never mind. I'm pretty sure it must be 512MB of DDR3 RAM. Quote
Miro Posted November 17, 2010 Author Posted November 17, 2010 it doesn't tell me. it shows System: Microsoft Windows XP Professional Version 2002 service pack 3 Computer:Intel® Core2 Duo CPU E8400 @ 3.00GHz 3.00GHz, 2.00 GB of RAM Quote
ReMark Posted November 17, 2010 Posted November 17, 2010 Well you certainly must know if you loaded the 32-bit or 64-bit version of AutoCAD 2011. Right? Quote
Miro Posted November 17, 2010 Author Posted November 17, 2010 No i didn't load Autocad , it is my work computer which i have inherited from a previous collegue who no longer works here Quote
