Convert a G-Code into geometry
15 years ago, I worked at a furniture company that ran their repair department with a AutoCAD R12 computer with lisp routines for converting geometry into G-Code that was recognizable by Gerber cutting machines. They also had lisp routines that would work the other way around, in that they would convert G-Code text files BACK into geometry, while also showing tool paths and the like. These particular routines were seldom needed or used.
The reason I mention this is to show that I know such a thing exists, for I have used it in the past.
Does anyone know where I could find a autolisp routine that would convert modern G-Code back into AutoCAD as geometry? I have looked online, and I cannot find anything lisp oriented. I found a few installable programs, but I would rather do it with a lisp routine right in AutoCAD. Such a routine would come in handy where I work and in checking G-Code files before actually running them, to ensure it cuts correctly.
The G-Code I wish to convert was programmed for a Komo Router VR 510 that cuts 4' x 8' boards with a wood bit and drills.
A sample of the code I wish to convert into geometry is...
:(3159-STLD 5/8 OSB)
N1G00G17G20G28G40G80G91Z0M5
N2G90
N3M08
N4G52X0Y0Z0
N5G08P1
N6(DRILL .34375 DIA.)
N7G28G91Z0M05
N8G90T2006M06
N9T102
N10G00G17G55X12.397Y41.4811M03S6500
N11G00G43H6Z1.6
N12G01Z-.06F400.
N13G00Z1.6
N14G00X17.2965Y14.1266
N15G01Z-.06F400.
N16G00Z1.6
N17G00Y16.6266
N18G01Z-.06F400.
N19G00Z1.6
N20G00Y32.7377
N21G01Z-.06F400.
N22G00Z1.6
N23G00Y35.2377
N24G01Z-.06F400.
N25G00Z1.6
N26G00X30.897Y41.4811
N27G01Z-.06F400.
N28G00Z1.6
N29G00X33.4083
N30G01Z-.06F400.
N31G00Z1.6
N32G00X51.9083
N33G01Z-.06F400.
N34G00Z1.6
N35G00X55.2499
N36G01Z-.06F400.
N37G00Z1.6
N38G00X73.7499
N39G01Z-.06F400.
N40G00Z1.6
N41G00X76.2611
N42G01Z-.06F400.
N43G00Z1.6
N44G00X94.7611
N45G01Z-.06F400.
N46G00Z1.6
N47G00X85.9215Y35.2377
N48G01Z-.06F400.
N49G00Z1.6
N50G00Y32.7377
N51G01Z-.06F400.
N52G00Z1.6
N53G00Y16.6266
N54G01Z-.06F400.
N55G00Z1.6
N56G00Y14.1266
N57G01Z-.06F400.
N58G00Z1.6
N59(DRILL .5 DIA.)
N60G28G91Z0M05
N61G90T2009M06
N62T102
N63G00G17G55X80.6091Y3.8266M03S6000
N64G00G43H9Z2.
N65Z1.6
N66G01Z-.04F500.
N67G00Z2.
N68G00Y14.4516
N69Z1.6
N70G01Z-.04F500.
N71G00Z2.
N72G00X62.6091
N73Z1.6
N74G01Z-.04F500.
N75G00Z2.
N76G00Y3.8266
N77Z1.6
N78G01Z-.04F500.
N79G00Z2.
N80G00X40.6091
N81Z1.6
N82G01Z-.04F500.
N83G00Z2.
N84G00Y14.4516
N85Z1.6
N86G01Z-.04F500.
N87G00Z2.
N88G00X22.6091
N89Z1.6
N90G01Z-.04F500.
N91G00Z2.
N92G00Y3.8266
N93Z1.6
N94G01Z-.04F500.
N95G00Z2.
N96G00Y22.4377
N97Z1.6
N98G01Z-.04F500.
N99G00Z2.
N100G00Y33.0627
N101Z1.6
N102G01Z-.04F500.
N103G00Z2.
N104G00X40.6091
N105Z1.6
N106G01Z-.04F500.
N107G00Z2.
N108G00Y22.4377
N109Z1.6
N110G01Z-.04F500.
N111G00Z2.
N112G00X62.6091
N113Z1.6
N114G01Z-.04F500.
N115G00Z2.
N116G00Y33.0627
N117Z1.6
N118G01Z-.04F500.
N119G00Z2.
N120G00X80.6091
N121Z1.6
N122G01Z-.04F500.
N123G00Z2.
N124G00Y22.4377
N125Z1.6
N126G01Z-.04F500.
N127G00Z2.
N128(ROUTER-BIT .5 DIA.)
N129G28G91Z0M05
N130G90T2001M06
N131T102
N132G00G17G55X78.0006Y18.3759M03S21000
N133G00G43H1Z2.
N134Z1.6
N135G41D01G01X78.2756F450.
N136X81.4856Y18.3758Z-.005
N137X94.0602Y18.3755F900.
N138G02X94.7532Y17.6286I-.056J-.7469
N139G01Y15.3484
N140G02X94.9823Y15.0036I-.1448J-.3448
N141G01Y4.5015
N142G02X90.7114Y-.2234I-4.749
N143G01X12.5282
N144G02X8.2358Y4.5036I.4566J4.727
N145G01Y15.0036
N146G02X8.4858Y15.3564I.374
N147G01Y17.6286
N148G02X9.2348Y18.3776I.749
N149G01X81.4856Y18.3758
N150X81.9856F900.
N151X85.1956Y18.3757Z1.6
N152G00Z2.
N153G40G00X85.4706
N154X78.0006Y36.987
N155Z1.6
N156G41D01G01X78.2756F450.
N157X81.4856Y36.9869Z-.005
N158X94.0602Y36.9866F900.
N159G02X94.7532Y36.2397I-.056J-.7469
N160G01Y33.9595
N161G02X94.9823Y33.6147I-.1448J-.3448
N162G01Y23.1126
N163G02X90.7114Y18.3877I-4.749
N164G01X12.5282
N165G02X8.2358Y23.1147I.4566J4.727
N166G01Y33.6147
N167G02X8.4858Y33.9675I.374
N168G01Y36.2397
N169G02X9.2348Y36.9887I.749
N170G01X81.4856Y36.9869
N171X81.9856F900.
N172X85.1956Y36.9868Z1.6
N173G00Z2.
N174G40G00X85.4706
N175X75.0746Y43.268
N176Z1.6
N177G41D01G01Y43.543F450.
N178Y46.753Z-.005
N179Y47.8551F900.
N180X95.9476
N181Y36.9821
N182X75.0746
N183Y46.753
N184Y47.253F900.
N185Y47.8551Z.296
N186X77.6826Z1.6
N187G00Z2.
N188G40G00X77.9576
N189X54.0634Y43.268
N190Z1.6
N191G41D01G01Y43.543F450.
N192Y46.753Z-.005
N193Y47.8551F900.
N194X74.9364
N195Y36.9821
N196X54.0634
N197Y46.753
N198Y47.253F900.
N199Y47.8551Z.296
N200X56.6713Z1.6
N201G00Z2.
N202G40G00X56.9463
N203X32.2218Y43.268
N204Z1.6
N205G41D01G01Y43.543F450.
N206Y46.753Z-.005
N207Y47.8551F900.
N208X53.0948
N209Y36.9821
N210X32.2218
N211Y46.753
N212Y47.253F900.
N213Y47.8551Z.296
N214X34.8297Z1.6
N215G00Z2.
N216G40G00X35.1047
N217X11.2105Y43.268
N218Z1.6
N219G41D01G01Y43.543F450.
N220Y46.753Z-.005
N221Y47.8551F900.
N222X32.0835
N223Y36.9821
N224X11.2105
N225Y46.753
N226Y47.253F900.
N227Y47.8551Z.296
N228X13.8185Z1.6
N229G00Z2.
N230G40G00X14.0935
N231G28G91Z0M5
N232G28G91X0
N233M09
N234G90
N235G52X0Y0Z0
N236G08P0
N237M30
Thanks in advance.
I suppose you already stumbled across this in your search?
http://www.timeguy.com/cradek/autocad
Only other thing I can think of is to check the CNC Zone website for an open source G-code CAD/CAM program.
Good luck.
Edited by ReMark
