therealsaint01 Posted November 17, 2010 Posted November 17, 2010 Hi Guys I need to put 171, x and y co-ords to make a bunch of points..the co-ords are in excel.. Is it possible to "copy paste" from excel to Autocad and the points will all be there-correctly? It just becomes a mission to punch them in manually. Thanks Quote
lpseifert Posted November 17, 2010 Posted November 17, 2010 Have a look here http://lee-mac.com/ptmanager.html Quote
rkmcswain Posted November 17, 2010 Posted November 17, 2010 Hi Guys I need to put 171, x and y co-ords to make a bunch of points..the co-ords are in excel.. Is it possible to "copy paste" from excel to Autocad and the points will all be there-correctly? Easy to do with a script file. 1. Open the Excel file. 2. Save it as a .CSV file (comma separated values). 3. Open the .CSV file in notepad, add two lines at the top: ._multiple ._point 4. Then save this file with a .SCR file extension. 5. In AutoCAD run the ._Script command, and pick the .SCR file above. Quote
fuccaro Posted November 17, 2010 Posted November 17, 2010 If you have in Excel the X in column A and the Y in B, enter in C1 =Concatenate(a1,",",B1) and drag down across 170 lines. You should get x,y in column C. Select the column and copy it (ctrl+C). In AutoCAD enter in the command line multiple point, click in the command line and paste (ctrl+V). But turn off the running osnap before that. Quote
BIGAL Posted November 18, 2010 Posted November 18, 2010 Hey Rkmcswain & fuccaro thats a couple of neat tricks, adding on if you want a line joining a sequence of points together then just "Select the column and copy it (ctrl+C). In AutoCAD enter in the command Line , click in the command line and paste (ctrl+V)." Repeat for group of points as required. Could probably work for other commands also. Dont forget insert block etc its very easy to write a script in excell adding the relevant commands as a column insert blockname x,y Quote
fuccaro Posted November 18, 2010 Posted November 18, 2010 ... and if you try to draw lines, you don't even need to enter REPEAT because AutoCAD will repeatedly ask for a new point until you terminate the command. The same goes for polylines. many years ago I used to use Excel to generate my scripts. Quote
