Hello sir,
i am a student of Auto Cad. i have to draw Faisal Mosque situated in IslamAbad Paksitan.its 3d model. can any one help??
regards
What have you done so far? Can you post some screenshots?
What problems are you having? Ask questions and you will surely receive answers.
Are you really using Autocad 2004? :cry:
Without a set of actual architectural drawings it would be a challenge since you would be "guessimating" dimensions. The nice thing about most mosques is that they tend to be fairly symmetrical. For example, you draw one minaret you've basically drawn them all. You can use the array command or even the mirror command to locate the rest of them. Same goes for the mosque itself. Draw one side and you've drawn them all.
Do you have a good working knowledge of the 3D commands in AutoCAD 2004? Do you know how to edit solids?
Where would you like to start? I suggest you start with a minaret.
How detailed do you want to make this model? Will you be creating the outer wall? What other details will you be modeling?
I wonder how Engineer is coming along with this project? :unsure:
I checked it out online and it looks interesting, but I would hate to have to do it on 2004 though. :ouch:
I searched for some images. With some plans, I would not complain to model it using AutoCAD 2004.
