wrmurphy81 Posted November 18, 2010 Posted November 18, 2010 Is there a trick to making parcel lines show up properly if the linetype is dashed or hidden? It seems like every time I change the linetype to dashed/hidden/phantom that it prints as continuous. Quote
ReMark Posted November 18, 2010 Posted November 18, 2010 It seems like every time I change the linetype to dashed/hidden/phantom that it prints as continuous. Are you printing from model space or a layout? Most linetype scale problems can be traced to LTSCALE and PSLTSCALE. Quote
wrmurphy81 Posted November 18, 2010 Author Posted November 18, 2010 I am plotting from layout. I tried to change my linetype scale to .01 (that usually works) but i keep having trouble with the parcel lines. I will Google those commands and see what happens. Thanks! Quote
sinc Posted November 18, 2010 Posted November 18, 2010 If you are using the standard linetype definitions, an LTSCALE of 0.01 should be creating dashes that are so small you would have to zoom in incredibly close to see them, and the printed output would look continuous. Usually, linetypes look right if you have MSLTSCALE=1, PSLTSCALE=1, and LTSCALE=1 or LTSCALE=0.5. Quote
