muck Posted November 19, 2010 Posted November 19, 2010 AutoCAD 2010 Is there any VBA code to create a pdf file. Maybe using something like Exportpdf command in AutoCAD without the page setup menu. Some that could be put in a batch loop in VBA. Thank you, Quote
muck Posted November 23, 2010 Author Posted November 23, 2010 Sub CreatePDF() Dim PtConfigs As AcadPlotConfigurations Dim PlotConfig As AcadPlotConfiguration Dim PtObj As AcadPlot Dim BackPlot As Variant 'Create a new plot configuration with all needed parameters Set PtObj = ThisDrawing.Plot Set PtConfigs = ThisDrawing.PlotConfigurations 'Add a new plot configuration PtConfigs.Add "PDF", False 'The plot config you created become active Set PlotConfig = PtConfigs.Item("PDF") 'Use this method to set the scale PlotConfig.StandardScale = acScaleToFit 'Updates the plot PlotConfig.RefreshPlotDeviceInfo 'Here you specify the pc3 file you want to use PlotConfig.ConfigName = "DWG To PDF.pc3" 'You can select the plot style table here PlotConfig.StyleSheet = ComboBox3.Value 'PlotConfig.StyleSheet = "Acad.ctb" 'Specifies whether or not to plot using the plot styles PlotConfig.PlotWithPlotStyles = True 'If you are going to create pdf files in a batch mode, 'I would recommend to turn off the BACKGROUNDPLOT system variable, 'so autocad will not continue to do anything until finishes 'the pdf creation BackPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT") ThisDrawing.SetVariable "BACKGROUNDPLOT", 0 'Updates the plot PlotConfig.RefreshPlotDeviceInfo 'Now you can use the PlotTofile method If PtObj.PlotToFile(Replace(ThisDrawing.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then MsgBox "PDF Was Created" Else MsgBox "PDF Creation Unsuccessful" End If 'If you wish you can delete th plot configuration you created 'programmatically, and set the 'BACKGROUNDPLOT' system variable 'to its original status. PtConfigs.Item("PDF").Delete Set PlotConfig = Nothing ThisDrawing.SetVariable "BACKGROUNDPLOT", BackPlot End Sub Quote
Cocoroboss Posted September 16, 2015 Posted September 16, 2015 Sorry to dig out this topic, I would like to know if it is possible to use "Export" as a VBA command in order to export the drawing to a PDF file ? I used the code you described and it works but it takes 25 sec. for one drawing. And when I manually do it on AutoCad I see that "Export PDF" takes less than 1 second after the click to make the wanted PDF. Is there a code to use the Export command ? I tried "SendCommand" but it doesn't work. Quote
