hi all
what is the use of COORDS system variable , can any one show this with an example?
From your AutoCAD Help file.
Coords
An integer whose value is saved in the Registry. The default value is 1.
"Controls the format and update frequency of coordinates on the status line."
Coords accepts values of 0, 1, 2 and 3. For an explanation of what each value equates to look on the Quick Reference tab in your AutoCAD Help file under the topic Coords System Variable.
