Wise Posted September 19, 2008 Posted September 19, 2008 hey guys I am looking for a quick way to add area's of closed polylines, for example I have several hundred closed polylines, and I need to know the total area for all of them, any quick way? or is it a check 1 at a time kinda deal? Quote
lpseifert Posted September 19, 2008 Posted September 19, 2008 Look here for Polyarea.lsp http://www.turvill.com/t2/free_stuff/index.htm Quote
rkmcswain Posted September 19, 2008 Posted September 19, 2008 You can also use the ._DATAEXTRACTION command to create a table that will automatically update if the polylines change. Quote
nocturne00 Posted September 20, 2008 Posted September 20, 2008 Nice tip, I always used a lisp like that to calculate areas, didnt know about that data extraction command. Quote
qball Posted February 19, 2009 Posted February 19, 2009 That turvill link appears no good anymore. But I found the lisp elsewhere. I don't know if this is a proper link. But it just downloaded right from google page. Anybody have ideas to make that output (the sum of areas) into a field text? That sure would be nice. www.turvill.com/t2/free_stuff/polyarea.lsp Quote
dtkell Posted February 20, 2009 Posted February 20, 2009 That turvill link appears no good anymore. But I found the lisp elsewhere. I don't know if this is a proper link. But it just downloaded right from google page. Anybody have ideas to make that output (the sum of areas) into a field text? That sure would be nice. www.turvill.com/t2/free_stuff/polyarea.lsp worked for me. Quote
sygboe Posted June 2, 2010 Posted June 2, 2010 how to you use the lsp files in Autocad LT 2010? thanks ive been using fields to auto calc my areas. This is great, but is there a way to also have a running total of several floor areas too? does seem sill that even LT that is used in Architecture doesnt have this tool built in. and and the autocad calculator resets itself everytime its so annoying. Quote
rkmcswain Posted June 2, 2010 Posted June 2, 2010 how to you use the lsp files in Autocad LT 2010? You can't. LT does not support lisp. That is one reason LT is a fraction of the price of full AutoCAD. There are 3rd party tools available that claim to run lisp routines in LT, but purchase and use at your own risk. ive been using fields to auto calc my areas. This is great, but is there a way to also have a running total of several floor areas too? I don't recall if LT includes the ._DataExtraction command, but if it does, you can use this. Quote
Lee Mac Posted June 2, 2010 Posted June 2, 2010 Areas & Perimeters to Fields Areas to Fields Areas to Fields in Existing Attribute/Text/MText Quote
einstainas Posted June 10, 2010 Posted June 10, 2010 you can download autocad trial version for 30 days.its enouth time to make the job done. Quote
jyotsnachavan Posted June 11, 2010 Posted June 11, 2010 Last time I have asked u about combining multiple layouts in Autocad to single pdf.Now I have tried these options through Pdf995, it is possible to create Multiple layouts of dwg file into single pdf.But this is not reliable.I have attached image here, this shows two options i.e.combine pdf995 print jobs & combine with previous pdf995 print jobI am using first option because I have three layouts which i want in single pdf file for one drawing.another dwg also have three layouts & i want single pdf for these layouts. both pdf,s should be separate.So I am not using second option from that window.But problem is if i am using first option from window only yet it merges second pdf with first one whether my second option is off..Please helpJyotsnao:) Quote
