GAC Posted September 19, 2008 Posted September 19, 2008 I have several files with devices linked to the EPD I had to re-number my sheets and file names but after I re-numbered my file names the EPD is no longer able to find the data. Any solutions? Quote
Strix Posted September 22, 2008 Posted September 22, 2008 what did you do to solve it GAC? Just incase anybody else has the same trouble Quote
GAC Posted September 22, 2008 Author Posted September 22, 2008 Lets say you have a file called E1 if you change it to E2, E2 will have the info you put on E1 and the project database will start to prompt you that E1 can't be found and do you want to remove the data from that file you select yes and the info will only be on E2. Hope that make sense! Quote
GAC Posted September 22, 2008 Author Posted September 22, 2008 Yes! when you rename the file it keep the info on both files but it can't find on of them so you tell it to remove the info from that old file name. Quote
