Jennifer Dillon Posted November 23, 2010 Posted November 23, 2010 Help! I'm trying to create a rope light effect in a suspended ceiling using photometric lights and they're not showing up in the render. I'm using mental ray daylight, sky portal and global illumination. Any suggestions? Quote
Cad64 Posted November 23, 2010 Posted November 23, 2010 Is this an Autocad question or a 3DS Max question? You have posted in the Autocad section but your profile says you're using Max? Quote
Raudel Solis Posted February 5, 2011 Posted February 5, 2011 if its 3ds max go to render set up scroll down on common and find default scanline render click it and assign mental ray renderer. mental ray is required for proper shading and superior illumination Quote
