This may be a silly question, but I cant seem to find the right LISP function.
I need to convert a real to a string.
I have found:
atoi "string to integer"
itoa "integer to string"
atof "string to real"
but no "real to string"
Any ideas?
Lee Mac,
You may also want to look into the DIMZIN sysvar as it controls the format of the return for ( rtos ) calls. -David
Thanks for the help guys. - So something like this to set real to a string with 2 decimal places...
(defun test (/ olddim a1)
 (setq olddim (getvar "dimzin))
 (setvar "dimzin" 0)
 (setq a1 (rtos 123.32 2 2))
 (alert a1)
 (setvar "dimzin" olddim)
Correct.
A couple of things to watch out for with number to sting conversions:
(sslength) is documented as returning an integer. It returns a real when the PICKSET is larger than 32767 entities. (itoa (sslength ss)) can fail in that scenario (rtos (sslength ss) 2 0) will always work
(angtos) doesn't conform to to the units value. You must decrease it by 1. ie (angtos 0.785398 0 2) returns "45.00" Don't ask me why.
DIMZIN bit flag 8 did not use to be documented very well. Under VLisp help DIMZIN -> String Conversions is actually a good reference At least the A2K version.
-David
Thanks David, very informative.
I wonder why they chose 32,767 as the limit on integers.... seems quite random...
Lee Mac,
2 to 16th power is 65536. Take into account positive and negative, basically half of the number less a place for 0 and you get 32767. At least that's how I remember it. -David
  • 3 years later...
Need Help to create a code..
(setq a 123) ; if I add number
(setq a “point-123”) ;sometimes my input value should be like this
Please , I need help to use IF or COND function in lisp
For eg. If I enter 123, It should prompt like --- it is real
And if I enter “point-123” It should prompt --- It is String
thanks & regards
Bijoy
Use type function .
Examples ....
(setq a 123)
(setq b "Point-123")
(type a) ;; INT
(type b) ;; STR
thanks & regards
Bijoy
(setq answer (getstring "\nEnter Value: "))
(setq answer
(if (numberp (setq a (eval (read answer )))) a answer))
Wow, this is an old thread.
Your request can be a quite involved process due to LUNITS. I would be inclined to use multiple call to (distof) But I'm pretty sure you could figure out some way to fool it into giving a false return. -David
What i posted before involves conversion to correspond with the input:
now if you only need to "see" waht the user type
(prin1
(if (numberp (eval (read answer ))) "It's a number"
                   "It's a String"))
On another note, you said REAL
(setq answer
(if (numberp (setq a (eval (read answer )))) [b](float[/b] a[b])[/b] answer))
Yeah, I'll say! LeeMac wasn't yet familiar with RTOS :lol:
(setq answer
Try an architectural distance:
ie 1'-2"
ie 1'-2"
You got a point there David, with an input like that, the line wont be as generic as what my original intent was.
I have a feeling that the OP would want to use the input either for a value to write on an attribute/text or use the value for an arithmetic function.
Guess it all boils down to what the OP's planning to do with the value.
Good catch David. :thumbsup:
Just a bit of obscure maybe on the same theme
; if less than 10
(if (< (car dwgnum) 10.0)
     (setq newstr2 (strcat dwgname "-D0"  (rtos sheetnum 2 0)))
     (setq newstr2 (strcat dwgname "-D"  (rtos sheetnum 2 0)))
It should be pointed out here that the OP that you are referring to is a hijacker of the original thread, and bijoyvm should have started a new thread. Perhaps a moderator can sort out the mess :shock:
Oh yeah... :o , what am i thinking!! Brilliant deduction eldon. The OP would mean Lee Mac then.. (where is that fine lad anyway?..) guess we'll call bijoyvm "Other Poster" [that can also mean us??!!? darn...]
Careless of me... Good catch though.
-David
Yeah, some newbie by the name of Lee Mac, sort of rings a bell though doesn't it? :beer:
